Ink box full of brother j140 printer, how to clean it please help
mitpatterson
  • 74 Answers
SOURCE: Ink Absorber Box
If you lift the scanner and then carfully remove the cover that is on the same side as the ink cartridges the box should bein the back and you can remove it and clean it and let it dry for a while then reinstall it. if you need more help just do a live chat request for ME and i will help you
Posted on Jul 30, 2008
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Posted on Jun 05, 2009
  • 526 Answers
SOURCE: I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Posted on Dec 19, 2009
  • 10 Answers
SOURCE: My printer wont print even after changing ink and cleaning
I have a brother MFC 3240C. My Black ink stopped printing, the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Posted on Feb 03, 2010
Samyfam
  • 379 Answers
SOURCE: Brother MFC-465CN printer. Need a fix for error 46.
The problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
How to fix brother dcp J140 message unable to init 4f?
Error 4f means that your carete is damaged, probable after using not oryginal cartridges, it's reportable but to expensive. If you used brother ink, you can do an complaint I in brother service point.
Feb 16, 2015 | Brother DCP-J140W
I have a brother J140 W i followed your instructions to clear purge full ink box and it worked,I thought great,But now when i print the black ink goes into the yellow when I do a test I have 2 black i cyan...
Did you actually change any parts or just reset a warning? If you were getting a full error, chances are the purge system was full and needs to be changed. Likely what the problem you are having is that ink from the purge system is backing up and polluting your print heads.
Jan 04, 2015 | Brother DCP-J140w Wireless Compact Inkjet...
Replace ink
Take cartridges out of the printer, inside cartridge case if you look inside, in the back-middle part of it, you'll see black plastic. Take some swabs and wet them in alcohol, with it try to clean inside of the plastic.
Pict. is from DCP-J140 but PCB responsible for ink level recognition looks quasi the same. (Sorry for my English)
Mar 19, 2014 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-J4110DW. Why is the ink absorber full?
The ink absorber box or flushing box is nearly full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up. http://support.brother.com/g/b/faqlist.aspx?c=as_ot&lang=en&prod=dcpj4110dw_eu_as&tabid=2
Feb 16, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
How to change the ink box
Sir/Madam
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. Because these components are periodic maintenance items, the replacement is not covered under the warranty. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
Other reasons for cleaning are:
  1. The machine automatically cleans after clearing a printer jam.
  2. The machine automatically cleans itself after sitting idle for more than 45 days (infrequent use).
  3. The machine automatically cleans itself after the ink cartridges have been replaced 12 times.
If your question was not answered, please check...
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002700/000051/faq002751_003.html?reg=us&c=us_ot&lang=en&prod=dcpj140w_all
OR
If You Still Need Assistance Then Follow Us For ON :
Brother Printer Support
Feb 03, 2014 | Brother DCP-J140W
Ink absorber full brothers
Sir/Madam
The ink absorber box or flushing box is full. These components are periodic maintenance items that may require replacement after a period of time to ensure optimum performance from your Brother machine. The need to replace these items and the time period before replacement is dependent on the number of purges and flushes required to clean the ink system. These boxes acquire amounts of ink during the different purging and flushing operations. The number of times a machine purges and flushes for cleaning varies depending on different situations. For example, frequently powering the machine on and off will cause numerous cleaning cycles since the machine automatically cleans upon power up. The use of non-Brother ink may cause frequent cleanings because non-Brother ink could cause poor print quality which is resolved by cleaning. The more cleaning the machine requires the faster these boxes will fill up.
The ink absorber box or flushing box will need to be replaced.
  1. Machine automatically cleans after clearing a printer jam.
  2. Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
In Case Your Not Able To Clear Your Problem Then Go to Official Brother Printer Website: http://welcome.solutions.brother.com/BSC/public/as/hk/en/faq/faq/000000/002700/000051/faq002751_000.html?reg=as&c=hk&lang=en&prod=mfcj6710dw_all
Or
Still Having problem Then Follow Us For On:Brother Printer Support
Jan 23, 2014 | Brother MFC J220 Multifunction Printer
Error Message- Ink Absorver Full-MFC-J415W"
Sir/Madam
Your Brother Printer Machine automatically cleans after clearing a printer jam.And Brother Printer Machine automatically cleans after sitting idle for more than 45 days (infrequent use).
To solve the problem:
The ink absorbed box or flushing box will need to be replaced.
In Case You Still Need Online Help For Brother Printer,Then I Suggest You Follow Us For Brother Printer Support
Dec 20, 2012 | Brother Ink for Mfc J415w Printer
My Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Jul 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
20 people viewed this question
jasbo
jasbo
