Question about HP Office Equipment & Supplies
HP Designjet T770 - System Error 86:01 and System Error 42:10 Continuous noise (buzzing) on the display panel (operator panel) at startup.
New power supply, new formatter board with hdd
Joed911
  • 4338 Answers
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
  • 53 Answers
SOURCE: hp designjet 500 does not work
You probably have a problem with dry ink in the service station. This is the "tank"on the right hand side of the plotter which collects all your wasre ink. I would have a guess that because of the long standing period this has dried and is preventing the station from moving and cleaning the heads. You will have to remove the right hand cover of the machine, then looking directly downwards just behind te display panel you will see two torx screws, loosen them. The service station can then be removed and cleaned. Be sure to disconnect the small plug on the service station motor and fan, also remove the motor and fan before cleaning the station with water under a tap. BEWARE this is a really messy job, your hands will be black (use dishwashing gloves) and it takes a really long time to clean it properly, wait for it to dry in the sun and re- assemble.
Good Luck
Dave
Posted on May 04, 2009
SOURCE: hp designjet 9000s system error 1290
sistem error 1290
Posted on Feb 20, 2010
seeker5211
  • 1089 Answers
SOURCE: HP Designjet T770 HDD error
Did it ever work?
You are using the Post Script drivers, right?
Power down the printer from the back. Disconnect the power cord. Plug it back in and power it up.
Check the graphic language setting of the printer(look at the User Guide)
Resend the file.
Upgrade the firmware to the latest version (www.hp.com/#support)
Posted on Feb 10, 2011
Testimonial: "thanks, We actually had someone from another governmnet department that uses the exact same printer. and once we connected he gave the exact advice. "
SOURCE: hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Posted on May 05, 2011
How i can cancel the purge tube process in hp t770 plotter?
Here is a service manual that might help you.
http://www.partsnow.com/docs/service-manuals/hp-designjet-t770-t1200-service-manual.pdf
May 24, 2014 | HP DESIGNJET T770 Printer
Taking machine apart
i have 45.1:3 for t770
Nov 28, 2013 | HP DESIGNJET T770 Printer
79:03 error code t770
my ploter problrm t610 printer ready but carriage left side stucking and error showing on display 79:04 than replaced 3 no print head but not tready ploter why? i have replaced tralling cable .timing belt; formatter card , encoder strip , carriage block with carriage pcb but same problem .pls shuotout my issu.
Feb 11, 2012 | HP DESIGNJET T770 Printer
Hp designjet 800 error 2:10
System Error: 02:10
Is a carriage failure.
Get someone to look at it, possible carriage assembly replacement
Oct 27, 2011 | HP DESIGNJET T770 Printer
Designjet T 770 error 47:01
It's a "star wheel motor" error.
Try unplugging power cord from wall.
Plug it back in and power on.
If error persists, a technician is going to have to troubleshoot the printer.
Jul 15, 2011 | HP DESIGNJET T770 Printer
Just got a new HP Designjet T770 hard disk printer, keep getting error code 21.1:03, turned power off and unplugged, still receiving same error code
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
May 24, 2011 | HP Designjet T610 InkJet Printer
My hp t770 have this error 59.2:00 after repalcing formatter board plz help me
A 59.2:00 error says that a reused part has been installed.
If you paid for a NEW formatter get your money back and shop somewhere else.
If you paid for a repaired/reconditioned part, it won't work.
You need a NEW formatter.
Mar 18, 2011 | HP DESIGNJET T770 Printer
Service Manaul T770
error 59.2:00 for t770
Aug 16, 2010 | HP DESIGNJET T770 Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
