Paper is jammed right behind output rollers. It
Paper is jammed right behind output rollers. It can be seen from the front but cannot be seen when the rear door is opened.
  • mchughdj Jul 25, 2009
    Used small needlenose as recommended. I hope that this is not an omen of future performance as this happened on setup. Thanks.
  • 25 Answers
If the printer is under warranty do not do anything, call for service. If it is not under warranty carefully try using thin needle nosed pliers or forceps to reach in and remove the paper jammed inside.
Posted on Jul 25, 2009
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
I was copying using the rear paper tray when I got an error message. "Paper output slot. The paper is jammed. Clear the paper and press OK." I do not see any paper. When I turn it on, it...
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Check this link for tips;
http://www.ehow.com/how_113761_clear-printer-paper.html
Aug 09, 2011 | Canon Office Equipment & Supplies
What is a media jam and output tray is missing error? I could not find what these terms mean in the troubleshooting section.
Sounds like a little piece of paper is jammed on the rollers on top, or you have a bad sensor. Get in there and blow it out with compressed air or if it under warranty send it back.
Oh btw media jam (paper)and output tray(top part where paper comes out) is missing error (sensor is prob bad)
i hope this helps
Mar 01, 2011 | Samsung CLP-315W Laser Color Printer
I removed a jammed sheet of paper through the front opening, Had to pull real hard. Since then, when printing or copying, printer feeds up to 4 extra sheet with each printed page. I suspect some piece of...
Please see this solution from Canon. It is recommended you check your manual for the proper procedure for clearing paper jams. Incorrectly removing jams could damage your printer. Trust the following helps resolve your current issue.
If you do not have a manual it can be downloaded from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#BrochuresAndManuals
Issue: More than one sheet of paper feeds while printing
Solution: Clean the paper feed rollers using the MX300 operator panel
sikaku.gif Cleaning the Paper Feed Roller (Roller Cleaning) Clean the paper feed roller if paper is not fed properly. Cleaning the paper feed roller will wear the roller, so perform this only when necessary.
1. Make sure that the machine is turned on, and then remove any paper from the Rear Tray.
2. Clean the paper feed roller.
(1) Press the Menu button repeatedly until MAINTENANCE appears.
(2) Press the l_mark_s.jpg or r_mark_s.jpg button to select ROLLER CLEANING, then press the OK button.
The paper feed roller will rotate as it is cleaned.
3. Repeat step 2 twice.
4. Open the Paper Output Tray.
(1)Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
(2) Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
5. Make sure that the paper feed roller stops rotating, then load three or more sheets of A4 or Letter-sized plain paper in portrait orientation in the Rear Tray.
Set the Paper Thickness Lever to the left.
6. Repeat step 2 three times.
The paper cleans the paper feed roller as it feeds through the machine.
If the problem is not resolved, wipe the paper feed roller (A) located on the right side inside the Rear Tray with a moistened cotton swab or the like. Rotate the roller (A) manually as you clean it. Do not touch the roller with your fingers; rotate it with the cotton swab.
Dec 25, 2010 | Canon MX300 Office All-In-One Printer
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
Paper jam in output tray is displayed but i cannot solve
When it says that it usually means there is a paper scrap in the sensor flag that is under the long gray roller. It is a black plastic tab toward the right side behind the white plastic guides that the paper comes out under. You need a flashlight to see it and you need to be careful not to break the tab.
Apr 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Get E3 error but can not see any reason for the error. Have reset will clear the error but still no printing. The problem started while printing a page. The error was that the paper was jammed and would...
There's a hidden sensor lever under the white guides behind the platen roller. Either a scrap of paper is holding it up, or it could be bent from pulling out a jam. It is a black lever behind the platen roller slightly to the right of center. You may need a shop to repair.
Jan 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
Paper jam in hp photosmart c4280
What have you got to loose, get in there and try!
Mar 27, 2009 | HP PhotoSmart C4280 Laser Printer
k24674
jasbo
jasbo
