Question about Tools & Hardware - Others
What is the dial with arrows used for? It is located on the top of the gun.
  • Raynard Meyer
    Raynard Meyer May 19, 2017
    I have a air ace bradnailer and staple gun and was wondering what the dial with arrows used for. It is located on the top of the gun.
    Top Expert:
  • Tools & Hard... Master
  • 26,210 Answers
Depends what tool you are asking about.
Posted on May 18, 2017
No mark or arrow to set the clock by. I've used many timers and all had something... a mark of some kind to turn to in order to set the present time . This has nothing that I can see except the dial with...
Is there a second dial located on the face...
http://waterheatertimer.org/images/Current-time-166.jpg
http://waterheatertimer.org/How-to-set-timers.html
Sometimes there is a raised mark you can feel with finger.
Another way is to look down into the groove where the timer dial rotates.... and locate the tiny switch that is pushed when dial rotates... this will be the current time location... this will generally be 1-2 hours before or 1-2 hours after top center
Gene
Water Heater Timers Save Money
Mar 21, 2015 | Hardware & Accessories
Keyboard works but cannot dial
I think key pad must be removed to clean contact surfaces.
Sep 08, 2008 | RIM BlackBerry Pearl 8100
How do I set the date
1. Close the lens barrier and press the LCD monitor ON/OFF button to turn on the LCD monitor.
2. Press the Menu button to display the Menu.
• See page 37 for how to use the Menu.
3. Press the top/bottom arrows on the Jog dial to select MODE SETUP, then press the right arrow.
4. Select the date order using the top/bottom arrows on the Jog dial. Press the right arrow on the Jog dial to adjust the first setting month/day/year.
5. Press the top/bottom arrows on the Jog dial to adjust the first setting, then press the right arrow on the Jog dial to adjust the second setting.
Repeat until the minute is adjusted.
• 00 will appear for the year 2000.
6. Press the OK button to save the setting. Press again to cancel the Menu.
• For accurate setting, press the OK button when the clock hits
00 seconds.
• If the Menu button is pressed before the OK button, the
setting and Menu mode will be canceled
Jan 31, 2012 | Olympus D-460 Zoom Digital Camera
Cannot get the pulse tone off the line and that prevents from voicemail access and call forwarding HELP!
In guessing that since your lines have defaulted to pulse dialing that you have an older Nortel system such as an 8x24 or a 6x16 system. That being said you'll need to program touch tone dialing on each line.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
4 top line/feature keys are now used for programming
Press the show key (top right arrow)
the display will say1. trunk/line data
Press the show key (top right arrow) .
the display will say line 001.
the display trunk data
press the show key (top right arrow) Press the next key 7 times(bottom right arrow) .
The display should say Dial mode: pulse.
Press the Change soft key (below the display).
the display should now say tone. press the heading key (top left arrow) to get back to "trunk/line data" repeat the steps for the remainder of your active lines
press Rls when finished
Nov 04, 2010 | NorStar M7208 Corded Phone
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
The display should say speed dial#:--
enter in the speed dial number you wish to program.
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
INSTRUCTIONS NEEDED ON HOW TO SET UP SPEED DIAL NUMBERS FOR WHOLE OFFICE SYSTEM
Speed dial numbers 001 -255 (01- 70 on older versions) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Jan 08, 2010 | NorStar T7316E Corded Phone
How do you access bypass tray?
The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
Dec 17, 2009 | Canon LaserClass 2050 Plain Paper Fax
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
How do you load brads into the Arrow t50pbn staple gun?
Look at rear handle and push in tab then pull out load brads. Please Rate Thanks
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Tools & Hardware - Others Logo
74 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
