Question about The Office Equipment & Supplies
I have a DuPont lighter serial numberM4KV12....green in colour with Chinese writing.....what's the value?
Value of a used Dupont lighter #DB8227. Also how old is it?
this question does not belong on fixya...reported
Jul 15, 2017 | Cars & Trucks
How do i reassemble my dupont minijet lighter?
The piezo spark generator has failed, what's the point of putting it back together
Throw it away, there isn't a manual with diagrams and it's impossible to describe how to fit it together without spending more time than it's worth.
May 06, 2014 | S.T. Dupont ST Dupont Minijet Chrome Grey...
What colour fuse is the cigarette lighter in a renault twingo
The best solution is to take it to the garage as no one seems to know the colour or value of the cigar lighter fuse in my 2011 Renault twingo pizaz so replacement will be a case of pulling each one in turn until the right one comes to light
Jun 30, 2012 | Renault Cars & Trucks
I want to identify and find gas and flints for my st dupont lighter.
I phoned a local supplier of my product, sent them photos and they emailed me back with a solution.
Jan 21, 2010 | Toys
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
S T Dupont "ping" problem..
The Ligne 1 does not 'ping'. The Ligne 2 or the Gatsby make the 'ping' sound when opened. It's a nice sound but i find it indiscreet in many environments and prefer the large size Ligne 1 precisely because it doesn't.
Nov 23, 2009 | Toys
20 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
