Question about The Office Equipment & Supplies
My printer has suddenly started printing everything in black and yellow. No other colours are printed and even the black has a yellow shadow.
silly girl
  • 513 Answers
SOURCE: colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around.,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
Posted on May 24, 2006
SOURCE: Black cartridge not printing
This might sound really silly, but when you removed the protective tape over the cartridge, did it all come off? I had this problem once, and the tape had separated, the coloured part had come off leaving a clear film over the print head. Once I peeled that off, all was well. Hope that helps. Aileen xx
Posted on Aug 22, 2007
SOURCE: Printer will not print black ink
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Posted on Jun 15, 2008
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
  • 1335 Answers
SOURCE: My printer is not printing the colour yellow even though the cartidge is full and new
If you have run the nozzle cleaning utility, and you are not getting any yellow output, the cartridge is most likely defective. This also occurs if you are not using OEM ink cartridges.
Posted on Apr 25, 2009
Copies are comming out of the printer with a shadow of the data from about 2" above
This sounds like a developer unit problem. Try just printing a few lines of text with a different colour each time, 1 red, 1 yellow, 1 black, 1 blue. See if it does the shadow everytime, or just on one of the colours. Chances are, one of the cleaning brushes on one of the cartridges is not doing it's job properly.
Jan 27, 2011 | HP Color LaserJet 2600n Printer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
My copier is printing yellow throughout the page when it shouldnt
all colour empty in your cartridge. only yellow colour is in. so all printing is yellow. black colour cartridge too empty.
Feb 25, 2010 | HP Officejet Pro L7650 Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
May 09, 2009 | HP DeskJet 1280 InkJet Printer
Printer is refusing to print colour, with full colour ink tank.
Have you checked the ink levels in your cartridges? Ink can dry due to usage and also due to prolonged non usage.
Apr 13, 2009 | HP LaserJet 1100 Printer
OKI C5100 alignment issues, I think
In colour menu
Performs automatic colour registration
adjustment. Normally this is done on power
on and when the top cover is opened and
then closed. This process accurately aligns
the cyan, magenta and yellow images to the
black image.
Use oki drums and toners, clean led heads
Dec 19, 2008 | OKI C5100n Laser Printer
Double printing
You need to re-align the heads of your printer... go to printer properties - then printer preferences - click on maintenance ... now align those print problems...
Oct 30, 2007 | Epson Stylus Photo R220 InkJet Printer
Colour printing
May 19, 2006 | Epson Stylus C64 InkJet Printer
18 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
