Question about Car Audio & Video
12volt cable wiring - Car Audio & Video
Show me how to wire farmall cub tractor when converting from 6 volt to 12 volt. It's a 1951 farmall cub
Replace the coil with a 12volt coil. Replace the generator with an alternator. Replace any light bulbs with 12volt. Fit the new 12volt battery in with the negative terminal to chassis! and there you have it.
Feb 02, 2017 | Farmall Garden
Wiring Diagram For 12Volt Monster Trax Convertible Car 12-Volt Battery-Powered Ride-On
type: redman 12v red convertible schematics or wiring diagrams search google images I found the pics!
Sep 20, 2013 | 12Volt Monster Trax Convertible Car...
Which cable is positive and which is negative 99 ford escort lx One cable has a like fuse box and a yellow strip other is black
if you probe wire with 12volt test light clip on light to bodyprob wires when light goes on that wire is positive if no light comes on turn car key to on
Nov 21, 2010 | 1999 Ford Escort
Have hooked up al conections properly acording to diagams but amp will not pwer up. tested wire conections and i am getting juice to the amp but still no responce fuse are good amp is brand new out the box...
If this is new out of box make sure you have 12volts to the amp turn on wire. You should have constant 12volt + to the battery terminal 12volt- to the ground and 12volt + from the head unit (radio) to the amp The turn on wire on most car stereos is a thin blue wire. run this wire to the amp's terminal and when you turn on the radio the amp should turn on.
Sep 29, 2010 | Pioneer GM-D7400M Car Audio Amplifier
Radio turns on and off at free will - can you
You have a loose connection at the harness at the back of the radio. Only 3 possible wires that could be loose its the ground wire, 12volt wire or the ignition wire. colors are usually red-ignition yellow-12volt black-ground. Make sure those wires are connected real good!! with tape or solder the wires together.
Mar 26, 2010 | 2000 Kia Sephia
3 wire system minn koto how to wire 2 12volt batteries to get 24 volt
this is called wiring in series. Connect the positive cable to a positive post on one of the batteries. Then conect the negative post on that battery to the positive post on the second battery. Then connect the negative cable to the remaining negative post and you will have 24 volts. You will need to get a short cable to connect the batteries to each othr. Hope this helps you, Jeepfxr
Jan 20, 2010 | Boating
Car Radio loosing memory
You need to connect the wire that goes to the continuous 12volt.
This is the problem you do not have the permanent 12volt lead wire connected.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Radio Communications
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
