Question about toner Office Equipment & Supplies
Hi good evening i have printer HL-1110 currently change toner ..... error USB002 appear...what do....
    Top Expert:
  • toner Master
  • 24,699 Answers
Reset tn 1000
Why do you want to reset?
Dec 04, 2013 | Brother HL 1230 Laser Printer
Hi, can you help? I am trying to hook up the
Since you changed from Wireless to USB I would recommend either reinstalling or selecting "add a printer" and allow the computer to automatically add the local printer.
Jun 07, 2010 | Brother HL-2070N Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Brother printer HL-2070N Stopped printing. Toner light stays on. Installed replacment toner cartridge. Rocked side to side to spread toner evenly. Cleaned the primary corona wire. Light still on. Will not...
go to the start of your computer and find the control panel and when you see the ad and remove program click it and and you see the currently install files find words brother printer HL. click it and remove after that please restart your computer din insert your brother printer installer cd into cdrm and install again maybe your current printer driver some files is missing, or reformat your pc using os/operating system and install the printer again make sure your printer have a load tuner or ink. thank you
Jul 03, 2009 | Office Equipment & Supplies
Low toner advise keeps on after changing toner and/or printing
Have you tried to unplug your printer and plug it back in, that will force the printer to re-check all its settings and it should notice that the toner is now full.
May 27, 2009 | Dell 1110 Laser Printer
Ink cartrige dell 1110
Exerpt taken from Dell Laser 1100 User Manual (p30)
1 Open the front cover.
2 Pull the used toner cartridge out and lift it up and away from the printer.
3 Unpack a new toner cartridge. Hold the cartridge carefully and gently shake it from sideto-
side 5 or 6 times to distribute the toner.
4 Pull the tape to remove the protective paper.
5 Locate the cartridge slot inside the printer, one on each side.
6 Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until
it snaps into place.
7 Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed,
printing errors may occur.
PDF Manual can be found here -->
The guide also contains pictures of what to do.
Jan 29, 2009 | Dell 1110 Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
May 30, 2008 | Brother HL-5240 Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
21 people viewed this question
Top toner Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
Are you a toner Office Equipment and Supply Expert? Answer questions, earn points and help others
