Took door off to clean inside i know where the 2 long screws came out of but can't put them back as the plate that looks as though it goes on will not line up and the screws appear not to fit
The back of the door is still in place as you look at it there is a spring either side, I had to undo 2 screws in the first place and the front of the door plus the handle fell apart
  • 74 Answers
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: plmv169dcd handle fell OFF
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If you need more help with disassembly, we have similar service manuals and have uploaded them to our site here, here, and here to help you.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
Posted on Feb 14, 2009
mikeTY
  • 8 Answers
SOURCE: put back togather
http://img107.mytextgraphics.com/photolava/2007/11/23/mx5184-48lorgeqx.jpg
check out this link for the spring location
hope this helps :)
Posted on Jun 13, 2009
SOURCE: Jenn-Air Dishwasher Handle Loose
This worked perfectly for me. Follow the link that shows you which two screws to take out. It is one screw on each side of the inside door frame. One on the left and one on the right (not the top one, but the second one down). Then pull the door handle upward about 2 inches and the whole washer face comes up. Jiggle it off and tighten the handle. Only tricky thing is that you need a star screwdriver.
The problem I had in the beginning was that I took off the middle screws on top (cause that's what it looks like in the picture), but it's actually the side screws. Don't take them all off - just the two you need.
- Pokey
Posted on Nov 03, 2009
  • 963 Answers
SOURCE: We have the thumb press elongated handle on the
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Posted on Mar 06, 2011
How to put the pressure switch back together?
Without having a look myself its a little difficult to know where the black plastic plate comes from. There are so many tiny parts in those things.
But normally when you have air coming from the pressure switch, it usually comes from the check valve, that is located at the other end of the pipe which attaches from the pressure switch to the tank, where it fixes to the tank, is where the check valve is. When there is no pressure in the tank, unscrew it, clean it up or replace it, then that should solve your air leak.
As for the pressure switch, either you need an exploded view of it so you can see where the plate goes, or you may have to replace it altogether
Aug 06, 2012 | Makita MAC700 2.0 HP Air Compressor
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
How to change air filter for 2007 volkswagen jetta ,2.5
Hi, on the VW Jetta 2006 to 2009, the cabin filter is underneath the glove box so lay down on the floor and look under to see the 2 plastic screws. Access is gained by removing two plastic screws and gently pulling down a piece of foam insulation. Once the insulation is removed you can see the filter 8 inch long by 2 inch wide black plastic face plate. You must slide the face plate toward the passenger side door.
The face plate will now come off and the filter will still be inside and you will have to pull it down. Debris will come out onto the floor mat below. Insert the new cabin filter, put the face plate back up an slide toward he drivers side to lock in place. Replace the insulation, re-screw the 2 screws, and you're back in business with fresh air and clean hands besides!
Take care
Aug 10, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
Cleaning oven doors and no user manual
Open the doors 90 degrees to the oven front, then look just above the pivot point / hinge on the doors, there is a little plate with a screw (one above each door) - loosen the screw and slide the bracket towards the middle of the oven - you can then lift and take the doors off their pivot points - the inner glass will then slide up from the bottom and out for cleaning - once done put the glass back correctly, the bottom is marked so it is put back correctly - make sure you locate the doors back correctly top and bottom and then slide the plate back to prevent the door being able to lift out while in use and tighten the screw back up.
Hope this helps you all.
Just found this out while @ my Aunt & Uncles - the manual did not make it very clear at 1st.
I am looking for an electronic versionof the manual so I can print them a larger A3 copy as their eye sight is not what it used to be and they get lost while trying to read with a magnifying glass.
Jan 31, 2010 | Belling DB90 Electric Kitchen Range
How do I remove the doorknob from a weiser passage set? Want to paint door and remove passage set. Can't seem to find any slot to remove doorknob.
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Nov 03, 2009 | Hardware & Accessories
Driver side door inside panel
look behind handle for screw under a little plastic plate, same in side grip where you close door, maybe 1 more behind relector on door if equipped with one, then pull door slowly away, you will hear pops when doing this, it is ok. they are plastic screw kida things but they shouldnt break. if they fall out, you will need them to put door back on
Jun 25, 2009 | 1996 Oldsmobile Achieva
How do i replace a passenger side mirror on a 2001 ford focus
Interesting and fairly easy to do. I pried off the black plastic interior trim piece by simply pulling carefully on the end facing the windshield, then pulling at the back end. Came off fairly easily. Once off, I could see the wire connector. The mirror has a short wire which goes through the body of the car and connects to the wire connector which comes from inside the door. I did have to take out the two screws holding the front part of the door panel. This was to weave the wires back through because the go below the top of the door panel through the door body.
Once that was done I found the main screw through a barely big enough hole in the door and took that out.
Once that was off, all I had to do was take out one more screw that goes through the front metal body of the door into the mirror assembly.
It was just a process of weaving the wire back through the door, then I installed the front small screw next to hold the mirror in place, then I put in the big screw that really holds the mirror on, connected the wire back together and put the screws back into the door panel. Snap on the inside plastic piece and you're done.
It took me about 30 minutes or so and I had never done it before.
Nov 13, 2008 | 2001 Ford Focus
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
Cleaned inside of door windows, need help putting back together.
Those are your door spacers... the screws that you took out first go from the inside of the door and threw the spacers and then into the handle.
Jul 03, 2007 | GE JBP22BK Electric Kitchen Range
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
