Question about Bernina Sewing Machines
Today when I turned on my Bernina 1130S the machine seems to be 'stuck' on back stitch. Help!
The 'back stitch' button is not stuck down but pressing it makes no difference to the direction of the feed. It is otherwise feeding through smoothly, just in the wrong direction. Yesterday the machine was working fine and I can't work out what might of changed. I would be grateful for any suggestions.
  • 201 Answers
SOURCE: Free Motion Sewing - Jams
I don't have a solution, but wanted to remind users of this machine that it does not do the proper free motion action until you reach a certain speed. This information is on page 26 of my manual (older machine, so page no. might have changed with newer manuals). You can stitch at the lower speeds, but it does not "hover" and allow you to move the project swiftly and smoothly.
If you can sew regular sewing without thread/bobbin issues, then it is probably something to do with how you have set/threaded/used the free motion to cause the stoppage. Make sure you have a sharp (i.e. new) needle of the correct size for your thread, that the bobbin thread is the same weight thread as the top thread. Turn on the Needle Down button. There is a Free Motion setting in the Set menu, but I have no idea what it does. I turn it on anyway, just in case! What foot are you using? If you don't have one of the free motion feet (there are quite a few to choose from!) use the embroidery foot (small clear plastic one).
Pam
Posted on Apr 15, 2008
bargainbox
  • 1388 Answers
SOURCE: bernina 1031
Remove the needleplate and check for a buildup of lint between the teeth, this is the most likely scenario.....clear out all the other lint while it is open, and do it regularly.
A small brush and vacuum cleaner are useful, just remove the bobbin case etc first !!
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
Posted on Nov 21, 2008
RickE1
  • 202 Answers
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Posted on Oct 07, 2009
Selected baste stitch on 1130S and after two stitches, needle shaft stuck up - tried turning off, tried clearing memory, tried unplugging. Still stuck
What is the brand of your machine? If it's a Bernina, sounds like the basting mechanism is stuck. A Bernina tech can release that for you.
Jul 18, 2017 | Sewing Machines
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Nov 01, 2016 | Bernina Sewing Machines
How do I satin stitch h on a Bernina 1130s limited edition?
Satin stitch is a very wide zig-zag stitch with a very short stitch length. I do mine by dropping the feed dogs and guiding the material through by hand (a lot like darning).
Jan 30, 2015 | Bernina Sewing Machines
How do I get more memory for my bernina 730?
Resetting factory settings in some models will only reset the settings of the machine and does not effect the stitch memory.
to clear the stored stitches from memory try the following.
press «clr/del» and left / right arrow
button at the same time
• release both buttons
• leave Memory by pressing the
Left / right button
• Memory is now completely
deleted
You can hold a max of 30 stitches in memory on most models.
Nov 20, 2014 | Bernina Sewing Machines
Needle won't go up and Down
Is this a Bernina machine with the needle stuck in the up position? If so, is the model something like a 930 or 1030 or similar?
I'll have a go at an answer but unless you give more information than this, it's not worth attempting.
Oct 17, 2014 | Sewing Machines
Why does machine sew then stop after maybe 8 or 10 stitches?
You obviously have a faulty machine take it back to your dealer where you bought or directly contact Bernina.
Best wishes.
Aug 21, 2014 | Bernina Artista 640E Sewing, Quilting and...
Bernina 1230 stitch problems
Cleaning and oiling "may" help, however, with the machine changing stitches on its own, sounds like it could be a computerized part. I've read somewhere that sometimes the board just needs a connection re-soldered, but figuring it out and then fixing it could be difficult. Some people who are "computer-handy" can replace the boards themselves if they can determine which board is at fault.
Apr 02, 2017 | Sewing Machines
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
Jun 07, 2009 | Bernina Artista 180
Bernina artista 640 embrodry
For a 640: Make sure the machine is off then Press the reverse button and the needle up/down button at the same time and keep pressing while turning on the machine until the service screen come up. Select the "i" icon and then the icon that has a picture with the clock and a question mark. That will show you the hours and stitch count used. To exit the service program just turn off the machine.
.g_thread_answer { overflow:visible !important; }
Jul 29, 2008 | Bernina Artista 180
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
