When washer starting to spin it faults out with code pf. Then washer just powers down. What does this mean?
    Master:
  • 238 Answers
Hello!
Code PF means that a power failure occurred on the control board during the program run.
In most cases, the reason for the code PF on the display is not in the washing machine, but in the problems of electricity supply of your house or apartment.Turning off the electricity or a power surge most often results in this error.
Posted on May 18, 2017
Master_Tech
  • 770 Answers
SOURCE: Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Posted on Jan 23, 2008
dutchman05
  • 487 Answers
SOURCE: washer has come on with
Means Power failure.
Disconnect for an hour and plug it in again.
That should fix it
Posted on May 01, 2008
Illeagle
  • 525 Answers
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Posted on Jun 04, 2008
SOURCE: Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Posted on Aug 09, 2008
SOURCE: Our Fisher & Paykel Washing Machine is not
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Posted on Sep 30, 2009
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code pf
This error means Power Fail PF, this indicates that the Power Went off during the cycle, or while it was ON. Simply turn on & off again, this should clear the fault code.
Apr 04, 2010 | Maytag MAH8700A Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Machine will not spin and displays FP fault
Hi There
I have this for you and i hope this will get you in the right direction. Let me know how this goes. By the way Merry X-Mass and a Happy New Year.
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
PF(Power Failure) error appears each time the washer starts.
PF simply means there was a power failure since the last time you used the machine.
To clear it - simply power cycle it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Pf and of codes comming up on screen
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Error code PF
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Won't run
found a pf not an a fp
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Error code PF
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
