Question about Garden
Garden landscape lights not working
These light will be two years old in October. I can hear 'humming' from power box but lights do not come on. I see no fuse on the power box and the two lines running to the two seperate rows of lights a secure. I have pulled up the lines and see no obvious problems. Any ideas? Sorry, I do not know what brand they are. We purchased from Lowes.
    President:
  • 1,714 Answers
Is the timing wheel moving? It sounds like the low voltage side of the transformer is out. Have you tried turning the 'manual' switch on? If you unplug the box and take the bottom off, there may be a fuse, it might be worth a look. other wise you will need a new transformer box. Which one you say, Add up the lights, figure 18 watts per and do the math. (10 lights @ 18 watts ea =180 watts.) You would get at least a 200 watt transformer.
Posted on Jul 25, 2009
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Landscape lighting transformer hums only when controlled thru photo-cell, and not when powered directly.
1) Copy following link for Intermatic/Malibu power pack photo-eye instructions, general troubleshoot, manuals, replacement trippers, and tips to prolong life of power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Brand and model of transformer and photo eye are unknown.
Wiring changes are unknown.
Volt rating of photo eye is unknown.
Wiring of photo eye is unknown.
3) Add a comment including details, and attach photo, after reading information on link above, for live response Jan 2013
Jan 01, 2013 | Home
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
Garden landscaper installed pump for pond became faulty a little over 2 years landscaper has refused repair or replacement even though it is gaurenteed for perod of 3 years
it is gurateed by the manufacturer, not the landscaper. Contact the company that made the device tand tell them it has failed. you will hae to prove that it is less than 3 years old., the reciept you got from the landscaper should prove the install date. they will send you a new pump, however they will not pay for removal and replacement, that will be your responsibility
Mar 17, 2011 | Plumbing
Unit was working fine today. I was repairing some connections in the landscape lighting cables and checking each connection after completing it. At one point, I was testing the lighting and got nothing. ...
The power pack should make a humming sound when ON
1) Maybe power to the plug is off
Plug hair dryer into plug and see if it works
Check your GFCI resets in bathroom and kitchen
Check breaker in box
2) Maybe time of day needs to be set
Unplug power pack > plug back in > set on-off trippers
Rotate dial counterclockwise to present time
Then rotate dial two complete revolutions and return to present time
Malibu homepage
Malibu manuals
How to select power pack: # of lights and length of wire
Oct 10, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I just bought all new lights (5) for my Malibu ML300 RTW. This has been working great for the last 3-4 years. I ran new wire and cannot get these lights to work. I can hear the transformer humming, so I...
Be sure that the wire is connected to terminals "A" and "B". The "C" terminal is not used. Sometimes you have to squeeze the connectors on the lights pretty hard to get them to make good contact. Also, try connecting one of the old lights just to see if it works.
Sep 05, 2010 | Intermatic Malibu 300W Power Pack...
When i plugg in my power pack it instantly tripps the breaker in my power box. i un plugged it and disconnected the wires it worked fine since june when i bought it. iturned it off over dec. because of...
Guess is that the primary winding on the transformer (in the box) has a shorted winding. No fix. Replace the transformer.... and be sure that the load (total wattage of the lights being serviced) does on exceed 90 percent of the power pack capacity.
Jan 09, 2010 | Malibu ML200RT - Low Voltage Power Pack...
My intermatic tranformer used for lv landscape lighting just died. Power is on but unit is dead. Do I just replace it? Is there a fuse blown?
Check the circuit breaker. Try to cycle it manually by turning either the timer wheel or the rotating the small timer pin. If you don't hear a hum and get no output, it is probably dead. You might be able to fix it, but they are not that expensive, so I wouldn't bother. In fact, I have two used ones I would like to sell because they are overkill now that I have put in a lot of LED lights.
Dec 23, 2009 | Intermatic & Malibu& 300 Watt Power/Pack...
Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
May 09, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Garden Logo
558 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
