Question about Sewing Machines
Looking for an exploded view of the thread tensioner for a Globe 550 sewing machine
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 69 Answers
SOURCE: Excess bobbin thread under the fabric
I know you hate to hear this but you are probably threading it incorrectly. Make sure that the presser foot is in the up position when you thread the machine. This ensures that the tension discs are open and the thread makes it in between the disc.
Posted on Mar 01, 2009
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
  • 255 Answers
SOURCE: sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Posted on Aug 02, 2010
Testimonial: "Thanks! That does help. Now I'll have to find your tip on Adjusting Tension =)"
I have a bernina 550. What should I set the tension when sewing with invisible thread?
When I took a quilting class, the instructor had us put the invisible thread spool in a coffee cup behind the machine. Then we taped a paperclip or safety pin at the top-back of the machine (with about half of it above the sewing machine) between the spool pin and the first thread guide. Then we ran the invisible thread through the hole in the paperclip/safety pin and through the remaining thread guides and tension disks. (Technically, we avoided the spool pin.) Do NOT put invisible thread on the bobbin. Then adjust the top tension like you would for regular quilting or sewing.
Aug 07, 2017 | Bernina Sewing Machines
Thread globe 877 sewing machine
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and then tweak it so the top and bobbin threads meet in the middle of the fabric.
Jul 28, 2017 | Sewing Machines
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
Mar 31, 2016 | Sewing Machines
I have a singer 500/550 .I'm trying too sew a straight stitch ,but I'm having trouble with the tension. What's the best setting? And i can't sew with needle in the middle position. Why
500/550? wow, that an old one. have you check your timing? or the bevel gears?
what type of problems are you having with the sewing. is the thread knotting up on the back side of the fabric? is the thread just breaking? or is it just missing stitches? does the needle hit the bobbin case?
I have a 600 series and I found that if i put the tension around 2 or 3 it sews the best.
too tight the tread breaks, too lose the thread knots up on the back.
I had to change out the bevel gears and have the machine re-time to stop the miss-stitching.
also may want to check your bobbin tension.
May 29, 2015 | Singer Sewing Machines
Manual for Globe 550
Have you typed in Globe 550 manual into the internet search?
Feb 04, 2014 | Sewing Machines
How do I thread the Lily 540 for twin needle sewing?
You need to have the auxiliry spool pin threaded, a twin needle of course, and the threading is the same exept when you go through the tension. You have to make sure you have one thread on each side of the center tension disk. And that's it. Make sure you only sew straight, or small zig zags. Or else you can break a needle.
May 06, 2011 | Husqvarna Lily 540 and 550
Assenbly of thread tensioner for singer sewing machine model 1014
i need an exploded view of the needle thread tensioner so i can know if mine is assembled right
Mar 21, 2010 | Singer Sewing Machines
I have a singer cg 550 sewing machine and I am not sure which slot to put the bobbin thread in first
If you put the bobbin in the case with the thread coming off in a clockwise direction, the thread should just fall into a slot and gently tug on the thread and it will slide through the tensions. Lay it across the bobbin case and then pick up the thread with the needle.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
