Question about Miscellaneous
Ll 81 error coming
What is this problem
  • Brad Brown May 26, 2017
    Hi nazeer khaja, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
My washing machine alarm "LL" then power is shutdown & cannot power on anymore
The LL error code indicates "Large Load Detected". If the load is not too large and you have taken some items out and it still comes up displaying the error code "LL" it may be caused from a friction issue. It could be the spinner support with bearing causing the code if it's creating enough friction. You did not indicate if it has any problems with draining water. If the washer is not able to drain completely it could also cause the "LL" error code.
Dec 17, 2013 | Kitchen Ranges
SEVER EROR 0X9010001
Was the error preceded by 81:01 or 81:11? That is the format for the actual error on a 500 series plotter.
If so then you have a Paper-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
Carriage Belt if it is frayed or worn out, if it is good then
Replace the Encoder Disk Assembly.
Sep 22, 2013 | HP DesignJet 500ps InkJet Printer
Write the expression in radicant exponent the given is square root of 81 what is the answer and the solution.
I come up with 3. (81^(1/2))^(1/2)=3. the Simplest form. I used 81^(1/2) because, 81 looks like 81 to the first power, instead of a fraction.
Jan 14, 2011 | Texas Instruments TI-89 Calculator
MY bfm588dq-81 scale is malfunctioning. The
Throw it away. The product sucks. I know, I'm throwing one away right now and I"ll NEVER purchase one again.
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
Fax sending problem - error code 81
Greetings John,
This error is for 81 Z no user profile for pre-process.81 error indicates that a temporary error has occured while testing. If cycling the power does not solve the problem you should replace the formatter board.
Also It could be a problem with the power supply or DC controller. There may fluctuating power issues with the formatter. Also did you replace the network card after replacing the formatter or did you use the same network card that was replaced before the formatter was replaced. It may be the new network card may have been damaged by the old formatter and gives the same problem now, and using the damaged network card may have messed up the formatter again. To test this replace both formatter and network card together.
Regards,
TechSup1
May 01, 2009 | HP COLOR LASERJET CM3530FS UP TO 31/30PPM...
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
