I am unable to access F M R instr I have the manual with inst. Switch on back panel power switch then press front panel power button holding the first silver button volume control. no results
  • 46 Answers
SOURCE: How to hook up the front panel switch for a Quicksilver2-cmt motherboard
You first need to know the make and model number of the motherboard. Most mobo's have the make and model printed on the board itself, other times there will be a sticker.
locate these and let me know what make and model and i can do my best to provide you with the manual.
Thanks,
Brad Nelson
Posted on Feb 21, 2008
compdoctor20
  • 172 Answers
SOURCE: gateway 503gr power switch
if you are a practical person, the power on switch is the crudest item ever on a pc. The switch simply completes a circuit. If you look on you motherboard at the front panel connector cables, you will see the two that go to the power on switch. remove them, flash a small screw driver across the terminals and it will come to life
Posted on Nov 15, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
We just unplugged our sony dvd player and plugged it back in and it worked.
Posted on Oct 14, 2009
  • 20 Answers
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Posted on Feb 15, 2010
  • 59 Answers
SOURCE: Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Posted on Feb 23, 2011
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
My whirlpool electric dryer wont turn on, it has power, the light comes on and the timer works but when i hit the start button nothing happens...
HI. There are two areas of concern here. You will need to test each area to isolate the culprit. Use the procedures to assist with the testing of the door, and start switch.
DOOR SWITCH:
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
Locate the door switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced.
START SWITCH:
Locate the start switch(Usually located in the control panel housing). it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
For a three wire switch, touch one probe to the terminal labeled NC (or CT1) and touch the other probe to the terminal labeled CO (or R1). You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
If the switch fails either test, it should be replaced.
Dec 18, 2009 | Dryers
My Kenmore model #110.68944891 starts when I press the start button, but stops immediately when I release the start button.
Open the control console to access the start switch. If you have 3 wires on the start switch,replace the start switch.
Nov 07, 2009 | Kenmore Dryers
Drum will not rotate when START button is pushed. Neptune Model MDE 3000 AYW
Hi. There are two problem spots that i would inspect to determine the actual issue here. These spots are the door, and start switch.
DOOR SWITCH
START SWITCH
Locate the start switch, it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
NOTE:-(Make sure the unit is getting power before you inspect the above areas for faults.)
Oct 19, 2009 | Maytag Dryers
Is there a Magic Focus function on 53XDF01B?
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Apr 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Gateway 503gr power switch
Nov 03, 2008 | Gateway (4000474) Motherboard
Unable to swith off
do a manual restart then swithc it off the usual way, to do a manual restart you hold down the black menu button and the top power button for 5-10 seconds it will restart with the apple logo on the front then once it has come up with the slider hold down the power button until it switchs off.
Oct 03, 2008 | Apple iPhone Smartphone
Need to reset my dvd player
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Feb 28, 2008 | Pioneer DV-285-S DVD Player
My pioneer xv htd330 is set to progressive scan and i need to change it back to interlace, but i can't see the menu on my tv. is there a way to reset it to factory settings
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Feb 28, 2008 | Pioneer Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
