What is the meaning of fault e13 - Washing Machines
2 Suggested Answers
Audioaholic
  • 376 Answers
SOURCE: what dose e13 means
error, code 13 for service man
Posted on Oct 04, 2009
Error code E:13
I thin E13 is motor error, I will check.
Sep 03, 2008 | Bosch Nexxt 300 Series WFMC2201UC
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
What is error code e13
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Electrolux EW1000i Front Load Washer
WHAT DOES E13 MEAN
E13 is for a washing machine door
Nov 05, 2012 | Cars & Trucks
What dose e13 means
Oct 04, 2009 | Black & Decker Heating & Cooling
Washer not draining and rinsing
Hello Wet Towels, well to be honest outside of the test program I have never seen a fault code E13. If it was an error E03 I would check my water to make sure it was turned on, the cold inlet hose wasn't pinched, or debre filling the filter screens in the hose or water valve. That is what the care and use says about E03. In the back of your owners manual it tells you what the fault means and how to correct it. If this doesn't work call for service to resolve your issue. Hope this helps.
Aug 10, 2008 | Washing Machines
Just moved
E13 code means Pressure switch Fault
To check :- Remove Plug First ( Remember Safety First )
The pressure switch is at the top, its move likely to be a blocked pressure bottle, which is under neath the tub accessed via the rear bottom access panel 3 to 4 screws. the bottle is on the side of the filter with a small clear tube going up to the pressure switch. Clean this bottle out.
E19 code means Power Failure during Programme
Mar 10, 2008 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
