Question about Building Materials
Have a 953cd remote that does not have any affect on the motor, lights flash within the unit but nothing happens at the door?????
SOURCE: Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Posted on Nov 10, 2008
  • 899 Answers
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
ktkodama
  • 37 Answers
SOURCE: Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Posted on Dec 30, 2008
Door Tech
  • 98 Answers
SOURCE: Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Posted on Jan 17, 2009
SOURCE: Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Posted on Dec 08, 2010
How to program spare Chamberlain 953CD remote
  • 1Enter your garage with your remote, and press and release the "Smart" button on the side of your garage motor unit. This button is located near the antenna wire and light lens.
  • 2Wait for the LED light on the motor to start flashing, and press and hold the button you would like to program on your remote opener.
  • 3Hold the button for up to 30 seconds until the main light on the motor unit flashes twice.
  • 4Release the button on your remote and wait 30 seconds for the LED light to stop flashing, which indicates the end of the programming sequence.
  • Nov 07, 2012 | liftmaster 371 Remote Transmitter
    Garage door opener won't work
    Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
    Aug 30, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
    Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
    Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
    Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
    I have a chamberlain liftmaster professional Formula 1 Garage door opener that has been working for 5 years. Now will not go down unless you hold the main button. Sensors blink when it hits within 3...
    Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. They each have a small light that should be lit, both should be the same brightness and not flickering ever so slightly. If not tweak them a bit. If both lights will not come on you have bad sensors.
    Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
    I have a Craftsman 13953919 door opener. My garage door opens during the day when I am not home. The alarm company calls me to let me know, and the police have been by twice. Nothing is stolen, so I can...
    Here are some things to check.
    Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
    If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
    Apr 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
    I have a chamberlain 953CD New will it work for a Lift-master ?
    You may need a C943 as the + can make the siginal different.[Chambelain or Merlin]
    Apr 03, 2010 | Chamberlain 3Button Remote Control Model...
    How do I open the 953cd remote to change battery?
    You will find the instructions on this web site.
    http://skylinkremotesonline.com/files/953D.pdf
    Mar 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Garage door remote control signal problem
    On the rear of the motor unit just to the left of all those white wires you will find a small LED. Random flashing is normal but if it is flashing rapidly it shows some type of interference. If this isn't happening then the most common thing is a logic board going bad.
    Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Nov 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Building Materials Logo
    Top Building Materials Experts
    hpgwva
    Tom Chichester
    ray gallant
    Are you a Building Material Expert? Answer questions, earn points and help others
