Question about Amana Washing Machines
AMANA TANDEM 7300 TYPE:S32-A NPW72 SERIES FRONT LOADER WONT SPIN/AGITATE BUT FILLS & DRAINS
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
ginko
  • 19396 Answers
SOURCE: water will not drain from
Hi.
You need to access drain pump and check drain hose at the back. There are also a couple of parts to be tested. For those you may want to call a technician.
The access to the drain filter should be located at the front bottom side of the appliance, behind a protective trim. In there you should find a cap that can be unscrewed to release water and remove blockage. Have a container ready to collect water. If there is no access in front, then access is at the back (uncommon).
If there is no blockage at pump, check the hose at the back.
Ensure that the height of the hose elbow is respecting the specifications indicated in manual. Check that the top of drain hose is not lower than 30" (760 mm) . A wrongly placed hose will result in water going in the washer drain pump and tub, causing drain problems and no spin.
To start and complete drain part of the cycle, the electronic control checks the input from pressure switch (which detects water level) before advancing to spin part of the cycle.The pressure switch is a round shaped parts connected to a long rubber hose that goes inside the tub. The switch and hose must be cleaned or replaced. Pressure switch is located in the control assembly.
Access the control panel and clean the hose attached to the pressure switch.
Also check the lid is closing well.
If lid switch and drain lines are OK, replace the pressure switch, which is difficult to test (it is tested reading impedance with tub full and empty. Before replacing the switch, you can try cleaning it and blowing into the switch pipe. Check also motor before replacing the switch. The switch is connected to a long rubber hose and it is located in the control panel.
Below an article about the no spin problem. If the problem is coming with no drain, check drain filter, drain hose at the back. If they are OK, the pressure switch may need to be replaced or the pump may be defective.
Here the general troubleshooting for no spin: If you have no spin there may be different reasons behind the problem.
Here the user manual:
Amana NFW7300WW Washer Laveuse Automatique a Chargement Frontal Guide d' Utilisation et d' Entretien - Front-Loading Automatic Washer User & Care Guide.pdf
Regards.
Ginko.
Posted on May 01, 2011
I have a Amana tandem 7300 front loader washing machine. It's stopped working nothing's happening except the display lights. Stopped in the middle of the wash cycle is there a reset button? Offbalanc
The only reset is to unplug the machine from power for about 5 min's and if that fails you may need to replace the washer timer control board.
Apr 19, 2017 | Amana Washing Machines
Amana tandem 7300 washer hums but won't spin. Stopped with clothes and water in it.
If you would drain the water out with a hose (siphon it out) and remove the wet clothes, then look underneath the machine and see if you have a drive fan-belt, you may find it broken or slipping.
A very few machines have a drive shaft with a coupling instead.
God bless your efforts.
Jan 02, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My amana tandem 7300 will not turn on any cycle it will go back to wash but does not turn on it just beeps please help if u can
It may think the door is open, front load machines will not proceed to fill if they cannot sense a locked door...
Apr 22, 2016 | Amana Washing Machines
I need to change the belt on front loader amana tandem 7300
The back doesn't come off - the 'shell' (top and sides) come off. Then you should be able to get to belt from the side, you'll need a lot of room to work with it.
Nov 21, 2013 | Amana Washing Machines
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Nov 28, 2010 | Amana Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
