Question about Shredder Office Equipment & Supplies
After a light tumble my shredder quit working, I wonder if there's a reset or something I can do to bring it back to life.
  • Shredder Master
  • 2,306 Answers
Make sure it's on the shredder basket correctly. There is a safety switch.
Posted on May 18, 2017
Testimonial: "Yes the shredder basket is on correctly and I have switched on/off/rev etc... but still nothing. Do you think I'll ever get it back? I knocked it over accidentally and it's hard to believe that it will be inoperable for good!"
  • Ellie Beserra
    Ellie Beserra May 18, 2017
    By the way, where's the safety switch located? I don't seem to see one.
  • robert May 18, 2017
    Well, most of these can only be put back onto their shredder basket one way and that correct way has a tab on the basket that trips a switch on the shredder body allowing it to work. So I was thinking that might be the issue since just knocking it over should not cause any issues.
Windows xp restore point How do I use it?
  • Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  • On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  • Oct 21, 2017 | ESET Computers & Internet
    What does the safety intrlock tab look like if broken?
    Something is out of place; either the bin or the sensor.
    Jul 14, 2015 | Shredder Office Equipment & Supplies
    Shredder stuck, no power light, but power strip works
    shredders do not have a long life time and are finicky. You have to pull all the paper out of the shredder to unjam it. I have trashed several. Be careful to not exceed the page limit as to how many pages it can shred. This is the primary cause of jamming. Also, using some light weight oil (3 in 1, for example) should be part of routine maintenance. good luck darlin
    Sep 15, 2017 | Fellowes Office Equipment & Supplies
    Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
    Janet McDonald,
    I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
    -Best Regards-
    Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
    Techko shredder model #SH4205PD. The shredder stopped working. After unpluggung it and sliding the switch back and forth a couple of times it worked. Now it has quit working again. what coulf be the...
    The micro switch referred to is to triggers from the presence of a piece of paper in the slot when on 'Automatic'. If this is stuck in the closed position it will easily be verified by placing a piece of paper in the accepting slot on the top of the machine. If it turns on it is stuck in the closed position. These shredders obviously get quite dirty and may simply need cleaning. Be Very Careful when working on any shredder! Also. the slide switch while basic in design has a number of wires on 8 poles and could also be the problem. As well if you these machines are protected by a thermal cut-off circuit if you overworked it give it sufficient time to cool down and reset. These are the most probably things to look at however, more in depth Dx may be necessary.
    Good luck.
    Mar 07, 2011 | Techko Office Equipment & Supplies
    Oil life % wont quit coming on --just had the oil changed but % info won't change back to good oil life
    there is a reset button- or do something in your car to trigger the reset. for example on most gm models to reset the oil light you turn the ignition on, but not the engine then hit the gas pedal 6 times (6 times under 10 seconds) and it resets it. You can try this but not sure it will work on fords, if it does not just call and ask your local dealership. god bless.
    Feb 17, 2010 | 2007 Ford Five Hundred Limited Sedan
    Paper got stuck. machine will not turn on.
    First, check that the machine is properly seated on the waste container. There is a switch that prevents the shredder's operating if it isn't properly seated. Will your "ready" indicator light up? If the machine will not turn on at all, try something else in the outlet the shredder is plugged into. If there is no power to the outlet, you probably tripped the breaker. Reset it and proceed as follows. Turn your switch to "off". Unplug the shredder and flip the shredding head upside-down on a stable surface. Remove anything that was previously hanging down. Gently remove stuck stuff, keeping your hands in a safe position. Place the shredder head back on the waste container and plug it in. Most all shredders have a reverse on them for just this occasion. Work the machine reverse and forward, until it releases. When in reverse, remove whatever the shredder gives up, with the switch set to off, of course. This should get you back in the shredding business. Next time you're at one of the office supply stores, get some shredder lubricator sheets. Using these from time-to-time lessen the incidence of jams.
    Enjoy! --W/D
    Jul 11, 2009 | OfficeMax 0M96431 Shredder
    Fellowes OD1500C shredder lights are on but will not shred
    Check the bin interlock to be sure it is working. If your shredder senses that the bin is not in place, it will not run.
    Feb 06, 2018 | Fellowes (R) OD1500C High-Performance...
    Heat pump unit won't run, possibly electrical?
    If there is no lights on the furnace/air handler, and no sounds from the equipment then it does seem to be an electrical problem.
    First try to reset all applicable breakers and fuses. If this does not bring something back to life, you most definitely need a professional on site.
    Jul 01, 2008 | Heating & Cooling
    Shredder quit working
    The motor has a thermal switch that stops it when the motor gets too hot.
    Jan 23, 2018 | Techko SH1524CP Shredder
    23 people viewed this question
    Top Shredder Office Equipment & Supplies Experts
    Ross Keen
    Dave Reilly
    Level 1 Expert
    Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
