Question about Head Office Equipment & Supplies
Z3100 does not accept print heads E/G & M/Y
Printer keeps wanting new/replacement print heads E/G & Y/M I Have installed new print heads but it keeps saying print head replacement not completed I've cleaned head contacts, etc. with no results or changes. I've replaced E, G, M & Y ink cartridges with no results or changes. Any suggestions appreciated
ctf1800
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00035736&cc=us&lc=en&dlc=en&product=305375&dlc=en&lang=en
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
  • 13 Answers
SOURCE: Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Posted on Aug 01, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
SOURCE: Print head is not installed. Install Print Head
Installed 2 new factory spec. print cartriges.
Posted on Feb 13, 2009
Printer not accepting new black ink cartridge
put that cartridge in and perform a head cleaning process, and allignment... follow the procedure (2 or 3 times if needed) and in the end, shut down the printer, disconnect usb cable (both end), then wait for some time, aprox. 20 sec. and then put both end in again, turn printer on and wait for ready signal or some sort of confirmation that all is ok... If not, replace or update the printer driver and software, or reinstall all printer software.
Apr 22, 2014 | Epson R1900 Printer
Hpz3100 cartridge expiration
1 - Leave the printer , turned on for sometime .
2 - open the door of the printer and take the cartridges out of the print head .
3 - Connect the cartridges again
4- Shut down the printer , wait for 2 minutes and then power it back on.
and try printing ..
Hope that will certainly work.
Apr 02, 2013 | HP Designjet Z3100 InkJet Photo Printer
Hi.. i have a lexmark z617 printer and everytime i want to print a document with colours, it power button starts blinking. When i removed the colour cartridge, then the power button stops blinking. what...
When did this start happening?
After a long time not being used, the ink dryes and clogs the heads. Try cleaning the heads and install a new ink cartridge. Run any fresh install that is issued with the printer.
Aug 24, 2010 | Lexmark Z617 InkJet Photo Printer
Any idea why all of a sudden my printer won't accept my ink cartridge? The power light keeps flashing and won't let me print. I have checked the cords, uninstalled and re-installed the printer and even...
I presume that your are replacing the ink cartridge with a new one. Although this may seem obvious, be sure that all removable tapes around the printer head have been removed. Sometimes this is not so obvious.
Oct 31, 2009 | Dell 810 All-In-One InkJet Printer
Canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
Communicates with XP-PC, makes all the moves and sounds- nothing prints
Hi, Hope this helps
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/hzMF5dB-ZMc&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Print Head install
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Jun 17, 2008 | Canon PIXMA MP470 All-in-One Printer
Ink cartridge stalled
hmmm..did you clean and recalibrate your print heads after replacement?
also, you might want a fresh set of print drivers. get em here
Mar 10, 2008 | HP PSC 1350v All-In-One InkJet Printer
21 people viewed this question
Top Head Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Head Office Equipment and Supply Expert? Answer questions, earn points and help others
