Question about Electrical Supplies
Oil pressure sender location on onan marquis gold 5500 recreation vehicle power plant
  • 29 Answers
SOURCE: oil pressure sender
It is located on the side of the oil pan, enclosed is a little more info on testing and installation.
TESTING
See Figure 1
  1. Unplug sensor connector and insert a jumper wire between terminals 1 and 2.
  2. Start the vehicle.
  3. If the light is on, check the harness and dashboard light.
  4. If the light is off, replace the sensor and recheck the light operation.
0900c1528008c49c.jpgFig. 1: Connect a jumper wire between terminals 1 and 2REMOVAL & INSTALLATION
See Figures 2, 3 and 4
  1. Raise and safely support the vehicle.
  2. Unplug the connector from the sensor.
  3. Unfasten the sensor mounting bolts and remove the sensor from the oil pan.
To install:
  1. Install the sensor into the oil pan.
  2. Tighten the sensor mounting bolts.
  3. Plug in the sensor connector.
  4. Lower the vehicle.
0900c1528008c49d.jpgFig. 2: The oil pressure sensor is mounted to the side of the oil pan-850 model shown 0900c1528008c49e.jpgFig. 3: Unplug the connector from the oil pressure sensor 0900c1528008c49f.jpgFig. 4: Unfasten the retaining bolts and remove the sensor
Posted on Oct 01, 2008
SOURCE: Location of oil pressure sending unit on 2003 GMC 4.3L
2 the right of dist. cap
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: location of oil pressure sender on '98 Linc. Navigator
the oil pressure sending unit is usally located in the same side the oil filter is and this is because the oil filter is connected to the oil pump so there should be one little single wire in that area
Posted on Jul 03, 2009
SOURCE: 5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Posted on Jul 23, 2009
SOURCE: where exactly is the oil pressure sender located?
On the end of the cylinder head. oil passage to camshaft.
Posted on Jul 24, 2009
Where is the oil sender unit on Onan marquis gold 5500 rv power plant
http://www.flightsystems.com/
upper right hand corner you can schedule a call from tom for free. He is an onan guru for the rv items. Or try calling and ask for tom specifically and he will be able to tell you right away possibly.
May 18, 2017 | Electrical Supplies
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
WHAT IS ERROR/FAULT CODE 37 ON A ONAN 5500 MARQUE GOLD GENERATOR ?
Code 37 is a bad set configuration, that means engine cranking speed and generator output aren't happy with each other..
Sep 30, 2014 | Onan Marquis Gold RV Generator 5500 Gas
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Jun 23, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan marquis gold gas generator 5500 stops running after 5 minutes
Check fuel pump pressure, how long has it sat. What load is on after it stops?
Jun 10, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Free Service Manuals
What is the question? You want a free service manual?
May 07, 2013 | Onan Marquis Gold Quiet Gas Generator 5500...
Jul 23, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
90 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
