Question about Hotpoint Kitchen Ranges
RGB745WEA3WW Hotpoint Range broiler & oven work broiler gas valve doesn't close completely close when shutoff
  • 10865 Answers
SOURCE: Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Posted on Oct 02, 2009
  • 139 Answers
SOURCE: Hotpoint gas range model RGB7458EAIAD oven won't heat up.
probably a bad thermostat
Posted on Dec 28, 2009
sawdust46694
  • 398 Answers
SOURCE: hotpoint oven not heating up;broiler ok
the element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Posted on Jan 19, 2010
  • 189 Answers
SOURCE: Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Posted on Mar 03, 2010
SOURCE: I have a model SF362LXSYO gas range that the broiler and oven
Very common problem. Replace gas valve. Part number 9761959
Posted on Jul 15, 2010
Turn on broiler, select hi or lo, wait, broiler won't light, no gas smell inside oven either so gas is not even flowing to the broiler element. What's wrong?
I hate to ask the obvious, but have you verified that the gas is turned on? If your main gas shutoff valve is outside, someone may have turned the valve off.... If you have other gas appliances, do they work OK? Valves can be different, but usually a valve is "on" when the handle parallels the pipe, and "off" when the handle is turned cross-wise to the pipe.
Dec 31, 2015 | GE Profile JGS968SHSS Gas Kitchen Range
My hotpoint gas oven stopped working suddenly. The broiler still works.
sounds like a bad igniter.. replace and you will be fine. could also be the dual gas valve but i doubt it,
Nov 25, 2011 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Converting broiler in oven from natural gas to lp gas on hotpoint gas range
On the oven portion you will need to turn the oriface clockwise all the way till it bottoms out. This is the conversion from natural gas to lp gas on all gas ovens. Also make sure the valve down toward the back has been flipped off of nat. to lp. Good luck
Mar 02, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Oven & broiler not working
Please follow this LINK for your manual
Jun 16, 2008 | Hotpoint RGB528 Gas Kitchen Range
Kitchen Ranges Logo
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
