Pincusion/Convergence Problem I just replaced the HV Splitter and it sovled my arcing problem. The TV comes on fine, but I have a severe convergence problem and the screen seems to be pincusioning at top and bottom. Also, my 'adjust projection TV' listing to adjust the convergence no longer appears on my menu screen. Even though I use to repair TV's, I have not had the pleasure of fixing a projection TV. Any clues as to what could be causing the problem?
  • Bassplyr
    Bassplyr Jul 26, 2009
    I know, I use to work on them. I have an Associates Degree in Consumer Electronics, but I've never had the privilege of working on a projection TV like mine, plus I don't have the schematic for it.
    This much I do know. It's component related. I believe it's a problem with a capacitor in the convergence circuit or a cold solder joint.
  • Bassplyr
    Bassplyr Jul 27, 2009
    The problem is intermittent. Last night I watched the TV without a problem for 5 hours. The next morning I turned it on it was okay for about 10 minutes, then it went out of whack while I was watching it. The problem seems indicative of a capacitor problem because the pincushioning slowly gets worse the longer the TV is on. I'm going to look for what you suggest anyway. At this point I've got nothing to lose. Hopefully I won't have to track down a schematic to find the problem.
  • 89 Answers
You can find some presets on the display section of the motherboard. You try adjust to fine tune the picture.
Keep a mirror in front of the TV and try adjust the presets slowly with the help of a properly insulated screw driver.
Caution TV venerates very high voltages.
Posted on Jul 25, 2009
  • shameer ahamed
    shameer ahamed Jul 26, 2009
    You can don't require the schematic for finding those presets, and this problem is not because of the capacitor dry soldering. It is because of the alignment issue. You can easily find the presets on the mother board and it usually lies near the cables connecting the mother board and the CRT and the presets names are usually printed on the board itself.
  • shameer ahamed
    shameer ahamed Jul 27, 2009
    Yup you are perfect, if the problem suddenly in the sense then the problem is with the active component. So you check the huge capacitor fixed near the LOT and check the appropriate voltage level to and from the CRT. It might happen because of the deflecting system.You can find a couple of capacitors near the control cables running to the CRT check that too and let me know.
When testing the hv flyback by turning on the tv, if tv stays on the hv splitter block is bad ,but what if tv turns off what you check next? thanks for the help.
first, I think you have this backwards----if splitter disconnected (look for physical signs or arcing or it burnt) the High voltage would come up and sizzle where it connects to the splitter.
If the set with the splitter disconnected still shuts down it is not the issue---got a D52 of some kind?
Nov 02, 2012 | RCA Televison & Video
Sony 60
Have you check the sleep timer? It could be possible reason why your tv shut off every 30mins. bc the timer was set.
Feb 20, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Hi, I have a sony rear projection TV. I am trying
The wire is the HV lead to the block or HV splitter.
At the splitter pull rubber boot back and press down and turn wire and it will come loose.
SD TECH
Jul 10, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
After replacing hv splitter and focus block and about four hours of adjusting the convergence board in the front I finally got a great picture, but now i notice when you have a title like on my dtv...
Is this set a RCA ? You may want to double check the seating of the Anode Lead from the HV Transformer to the HV Slitter, If pulled out
a little arching will occur with-in the Bock and cause premature failure if not corrected. Also make sure that all ground connctions are made from the CRTS to the HV Block if there are any.
Hope this Helps,
Skyassoc
Jun 20, 2009 | Televison & Video
Projection tv not working
I guess loud sizzling was from High Voltage Splitter in your TV. HV seems cracked and leaking high voltage.
You can observe and confirm it by removing back cover and power up TV from distance and check at rear of TV. Please take care and there should be little dark to observe arc from HV splitter.
If this is the case, HV splitter available in Part Store.
Dec 16, 2008 | Televison & Video
I hear a sound like a shortcircuit on backside?
Hello eduquiros,
First of all I think you are hearing a clicking sound right? That noise is due to the HV shutdown circuit activating, indicating that excessive current is being drawn. Now the fact that the TV is on is indicating that the current level is right at the point of shutdown, now I would like to know if you have the schematics for this TV? If so locate the input to the HV trippler and measure the voltage with a HV probe, and compare it to the value on the schematic. In addition you say you have a convergence problem, for that I would say you have to change out your convergence amplifier modules.
Now let's get the the over all issue here: Do you have electronics experience? if so you will need a HV probe, a multimeter, and a pattern generator to solve this problem. If you have these pieces of equipment great, if not you will have to get them. If you do not know what these pieces of equipment are, close the TV up and have a TV repair person come and give you an estimate on the repair costs.
If this were in my shop I would triage the issues you are having,
First find that sound you are hearing (the exact location) and determine if it is a clicking noise or a burning noise (arcing).
Second repair that convergence problem, compare the voltage readings with the schematic
Third repair the HV issue
This should leave you with a working TV.
REMEMBER if you do not have electronics experience, have a TV technician take a look at this set.
I hope this helps
Thank you,
Shuttle83
Jul 15, 2008 | RCA P46921 46" Rear Projection Television
RCA HD52W59 Projection Big Screen TV
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Rca ctc 169
Did you replace the STK convergence IC's yet? If not, thats your trouble, or you have a plug in the wrong place. i doubt if the yolk is bad, as that would most likly blow out the horizontal output transistor and the set would be dead. Good Luck, Please do not forget to rate this thread.
Dec 07, 2006 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
