Question about Uniden Lands Phones
I have a uniden DECT 1735 and I cant call out nor receive calls where is the base unit ringer
SOURCE: How to turn off telephone ringer on handset for
Just press the down arrow on the center button
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
  • 3 Answers
SOURCE: Continuous Flash of Visual Ringer(Uniden DECT 6.0 Cordless)
UNIDEN MODEL EZX290 HANDSET>>>VISUAL RINGET AT TOP (YELLOW LED) FLASHES. HOW DO I TURN THT OFF?
Posted on Dec 10, 2009
jyackle5
  • 8197 Answers
SOURCE: how do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Posted on Dec 31, 2009
PCTechOnline
  • 532 Answers
SOURCE: Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Posted on Mar 21, 2010
How do we program answering machine on dect 1735 cordless phone
Do you mean the Uniden DECT 1735? You can turn on the answering system from the base On/Off button. The rest takes the hanset or a call into the phone. Start with the phone in standby (no handsets in use). Press Menu on a handset. Use the Up/Down arrows to navigate to Answering Setup and press Menu again. To set the number of rings, navigate to Ring Time and press Menu again. Use the arrows to select a number of rings and press Menu to save. Press the Left arrow/Page key to go up to the Answering Setup menu. Press End to exit the menu system.
To set the greeting, you would navigate to Record Greeting in the Answering Setup menu. Press Menu. When you hear "Record Greeting", speak your message. Press Menu when you finish. Press End to save the message after you hear it repeated. Press Menu and wait for the "Record Greeting" prompt if you need to change the greeting.
The manual for this is available on the product site: https://www.uniden.com.au/product/dect-1735-2/. The direct link to the manual is currently https://www.uniden.com.au/wp-content/uploads/2017/06/DECT_17352_OM.pdf . See the section starting on page 20 for the different steps to set up the answering system.
I hope this helps.
Apr 15, 2018 | Dect Lands Phones
How to turn on telephone ringer on base set for Uniden dect 6.0 corded
While the phone is in standby mode (not on a call or doing anything in the menu or message systems), press the up-arrow button.
If you need a manual, you may download a copy here.
Oct 10, 2012 | Uniden D2998 Dect 6.0 Loud/clear Big...
I cant turn on my ringer on uniden cordless phone tryed to and cant get to adjust the ringer any ideas
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest that you select it from the list beginning here to download a copy of the manual.
Apr 30, 2012 | Uniden DECT 6.0 Cordless Telephone...
The ringer is turned off and can't figure out how to turn it on. So I'm not getting any calls. My message light does not come on either. Please help!
Hello
Examine the base of the Uniden cordless phone. Locate the "DND" button on the main base of the phone.The DND button means do not disturb and it puts the phone in silent mode when pressed
Reactivate the ringer by pressing the "DND" button again. All the handsets will ring when someone calls you.
Jun 10, 2011 | Uniden DECT 6.0 Cordless Telephone...
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Ringer off. How do I turn it on?
Handset - Push on the top of the square unipad (volume carrot up) repeatedly until the volume setting begins to climb from an "off" condition
Base Unit - Do the same with the "+" key
Nov 04, 2009 | Uniden DECT 6.0 Cordless Phone ID
I have the DECT 6.0 and My hand set wont ring. The base or the individual handsets won't ring when a phone call comes in
Ringer may be muted (turned off).
If you need a manual to check correct procedure, here is a link.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Select model and download manual.
Hope it helps.
Sep 10, 2009 | Uniden DECT 6.0 Cordless Phone ID
Jun 28, 2009 | Uniden DECT 6.0 Cordless Phone ID
No ringer in Uniden DECT 3080-3
I'm having the same issue, I'm going to exchange it today for another. I'll let you know if that solves the problem!
Mar 27, 2009 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
55 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
