Question about Dect Lands Phones
I have a DECT 1735 and it wont ring out and I cant get calls where is the base ringer switch
pazman
  • 81 Answers
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Posted on Mar 30, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
safenude
  • 124 Answers
SOURCE: ringer off displayed on base
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Posted on Jan 28, 2009
SOURCE: GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Posted on Apr 25, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
How do i unmute the ringer on my vtech dect 6.0 phone
Hi Angie.
The manual for this phone can be viewed here:
http://cdn-media.vtechphones.com/ecp/documents/product_Product/1681/UserManual/6351/ls6425-3_manual_i3.pdf
On Manual Page 20 / pdf page 23, it says that if the ringer is muted for a single call, that it should work again the next time someone calls.
However. page 57 notes that the base ringer volume can be set between 0 and 6, so it's possible your ringer volume is not technically muted, but just turned all the way down.
Manual page 62/pdf 67 has a half-page list of other reasons that the ringer might not ring. (It can also be turned off, and there are different adjustments for both the phone and the base unit.
Hoing this lets you figure it out!
D
Dec 03, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
Base
What model AT&T DECT 6.0 phone?
Jun 24, 2013 | AT&T DECT 6.0 Cordless Phone System with...
The ringer is turned off and can't figure out how to turn it on. So I'm not getting any calls. My message light does not come on either. Please help!
Hello
Examine the base of the Uniden cordless phone. Locate the "DND" button on the main base of the phone.The DND button means do not disturb and it puts the phone in silent mode when pressed
Reactivate the ringer by pressing the "DND" button again. All the handsets will ring when someone calls you.
Jun 10, 2011 | Uniden DECT 6.0 Cordless Telephone...
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
I have the DECT 6.0 and My hand set wont ring. The base or the individual handsets won't ring when a phone call comes in
Ringer may be muted (turned off).
If you need a manual to check correct procedure, here is a link.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Select model and download manual.
Hope it helps.
Sep 10, 2009 | Uniden DECT 6.0 Cordless Phone ID
Ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
May 26, 2009 | Uniden Cordless Phone
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Lands Phones Logo
Top Dect Lands Phones Experts
ray gallant
Steve F
Bill Boyd
Are you a Dect Lands Phone Expert? Answer questions, earn points and help others
