I have Firestik was working great with KODI but picture froze up and unable to change with the remote. *changed batteries with no luck What can be done?
ctf1800
  • 4402 Answers
SOURCE: wii remote has no power
try replacing the battery's, if that doesn't work try resyncing the remote, still dont work you will have to replace, try also to power/unplug the unit.
Posted on Nov 25, 2008
iamdev8it
SOURCE: sears remote keypad model clk1 fcc id hbw1579
http://www.lilocksmith.com/instructions/PDF_Files/LM_CLK1.pdf
Posted on Apr 12, 2009
  • 172 Answers
SOURCE: Samsung TV Remote
Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
Posted on Aug 24, 2009
tvtek
  • 1284 Answers
SOURCE: cannot change aspect ratio
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Posted on Nov 24, 2009
Testimonial: "Thank you very much. That answers the question. "
BillB-SA
  • 2761 Answers
SOURCE: The remote for my Bose Wave radio-CD no longer
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Posted on Dec 06, 2009
I downloaded a build and now have a blue screen and unable to proceed
In this case you should install the newest version of Kodi which is Kodi Krypton 17.6. From here you should try installing a new build. From the sounds of it, its seems as if there must of been a bad file format somewhere within your build download. Once you have downloaded the newer version of kodi, go to your downloads manager and click on the apk file for kodi krypton. Let it install. Once installed go into kodi krypton and then decide which build you are wanting to install. For a decent list of the 2018 kodi builds you can check them out below. With full tutorials and screenshots you should be good to go from here. Hope this helps and good luck with your android box.
Best Kodi Build List for 2018 Must Read Before Installing BestBox
Sep 12, 2017 | Ps Televison & Video
Installing build on em95x
Installing a build on the EM95X is quite the simple process. First you should update to the newest version of kodi. Which is Kodi Krypton 17.6. You can do that by checking out kodi's website here. Kodi.tv After that you need to install a build. There is a huge variety in builds today, some being good while others are not so good. I would suggest taking at look at the blog post below to see what are the best kodi builds for 2018. From there you can just click on the tutorials with sreenshots and it will walk you through the process, theres even Youtube Videos on there as well to help guide you. I hope this helps you out and if you do have any issues the support over there is great. Good Luck
Jul 31, 2017 | Televison & Video
How do I resolve the error code 104, using kodi tv?
means the Kodi app using the M3u Playlist has changed and the URL no longer exists, if this code comes up when watching live Tv and Kodi Hangs on a frozen picture...also means too many people are using the feed.
try updating the kodi app or update the m3u URLs list
Apr 26, 2017 | Televison & Video
I want to jailbreak my Amazon fire stick
Hi Jimmy
I guess you need to do some research on the internet then.
This site helps people to fix real faults.
We don't advise hacking (jailbreaking)
Good Luck
Mar 01, 2016 | Cell Phones
Model #_LT52152, when turn on TV no sound, sometimes picture frozen and sometime cannot change channel. Help!
Sounds like a firmware corruption. Contact the authorized service centre for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Mitsubishi LT-52151 52 in. LCD HDTV
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
LG VU TOUCH SCREEN IS FROZE. CAN I GET PICTURES
Have you tried taking the battery out? And if that doest work you can call LG and they can replace your phone within warranty.
May 09, 2009 | LG Vu Cellular Phone
Unable to bring up the setup screen for display option
can't get the frame to cut off and start back up to show the setup program
Apr 02, 2009 | PANDIGITAL PAN80-2 (892235000548) Digital...
Toshibe 36AFX61 36" TV
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
Sep 18, 2007 | Toshiba 36AFX61 36" TV
Televison & Video Logo
Top Televison & Video Experts
