Question about Taylor Hardware & Accessories
Taylor 5827-21 - I can set the timer but when I push the start button it does not start. How do I get it to start?
IFIXALL
  • 868 Answers
SOURCE: Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Posted on Jun 12, 2008
  • 659 Answers
SOURCE: drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Posted on Apr 09, 2009
Jahn27
  • 1554 Answers
SOURCE: turn timer to 60 minute
The most common cause of this problem is a blown thermal fuse located on the blower housing. It is wired in series with the drive motor and turns off power to the motor if it is blown. The heating circuit is activated by the motor through a centrifugal switch. No motor running, therefore no heat.
Please indicate the make and exact model number of the dryer for further troubleshooting and repair advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 04, 2010
Andriod Man
  • 271 Answers
SOURCE: Machine worked fine on one
wait until cool down and restart. if its starts then suspect a short winding in the motor. replace if needed.
Posted on Feb 09, 2011
  • 560 Answers
SOURCE: How do I set taylor scale so I get accurate weight
There is an adjustment on the scale itself. Just set it to zero.
Posted on Dec 06, 2014
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
Dec 06, 2014 | Taylor Health & Beauty
How do i set the clock on a taylor 5846 digital timer
Press the Mode button until you are on the clock.
Then press and hold the Start/Stop button for 3 seconds.
There should be a beep and the digits will begin to flash.
Press the Min button to increase the Hours and press the Sec button to increase the minutes.
When you have the time set, press the Start/Stop button to finalize the setting.
Nov 18, 2013 | Hardware & Accessories
How do I reset the clock on a Taylor 5846-9 kitchen timer?
Nov 03, 2013 | Taylor Hardware & Accessories
How to set the clock on a taylor 5846 Slim Digital Timer
Feb 13, 2013 | Hardware & Accessories
I need your help, my mom has a timer by Taylor,I cannot find the paper work on it. can you please help me it has a START/STOP button , a M button and a S button, I don't know how to work it, know nothing...
Love those Taylor Timers! From your description, I believe your mom most likely has the Taylor 5806 (picture below / product website: http://www.taylorusa.com/kitchen/timers/digital-timer.html).
If so, the small instruction sheet that comes with this upon purchase can be found here:
http://www.taylorusa.com/media/IBs/5806_ib.pdf
I hope this answer your question, and if so, please be so kind to give this a thumbs up! Have a good one!
Mar 05, 2011 | Taylor Hardware & Accessories
How do I reset the clock on a Taylor timer 5891-21?
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
Nov 17, 2010 | Taylor Hardware & Accessories
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
Apr 27, 2009 | Taylor Dual Event Mechanical Timer, 00521
Hardware & Accessories Logo
32 people viewed this question
Top Taylor Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Taylor Hardware and Accessory Expert? Answer questions, earn points and help others
