GE front loader Machine continuously fills and drains washer without washing clothes. Model #WPXH214A0WW
  • 82 Answers
Either belt (worn or broken, if belt driven) or main motor. Unplug unit, remove back access panel. Inspect mechanics for problems.
Posted on Jul 25, 2009
Washing goes thru fill cycle, and spins, clothes still wet and soap still in machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | GE WBB4500EWW Top Load Washer
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
GE clothes washer WHDSE820C1WW started filling itself up and i cant get it to discharge the water out, spin or anything
heatman101 .
Oct 10, 2010 | General Electric Clothes Washer Timer Hub...
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
It won't drain...
From your description, you could have a problem with one of several things.. You can run a few tests to determine the most likely area that is causing your problem ,,, If possible, can you unhook your drain hose from the drain and use a barrel to cycle water into ? (You can stop the washer any time to empty the bucket... Anyway, try running a wash load ( without clothes) and monitor the water flow... when the washer is pumping water out, you should have a fairly high stream flowing into the bucket. Using a bucket will rule out a clog in your house drain line...and provide d irect means to see how well the system pumps.. If the water is only trickling out during the drain process, then you have one of sveral problems.. The pump is clogged or defective, the supply from the drum to the pump is clogged and not allowing the water to be drawn into the pump or the outflow tube from the pump is clogged or crimped. Any of these problems will require you or a service person to gain access to inside the washer and diagnose the problem. I had a similar problem on an LG front loader and it was the pump itself.. One thing to remember is to use HE detergent for these front loaders.. and a very small amount of that.. Hope that helps...
Aug 04, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
134 people viewed this question
Top Washing Machines Experts
