Pilot light stays on but burners will not fire up
SOURCE: Pilot Light
i had this trouble with a different fryer. We had lpg instead of natural gas. check youre using the correct gas.
Posted on Oct 20, 2008
  • 24 Answers
SOURCE: pilot light won't stay lit.
most common cause of the described symptom overheating the thermocouple! a thermocouple produces millivolts of electricity based upon a differential of temperature between the tip and the base. If it gets too hot it will not work correctly. If the pilot flame is too large or the main burner flame is contacting the thermocouple or the thermocouple is too cheap or old all can cause this issue.
Posted on Dec 18, 2008
  • 75 Answers
SOURCE: When control knob in"pilot" position, burners light
It has a thermo-couple that lets the gas valve know that the pilot light is on. If it does not get the heat signal to the valve, it will not turn on the gas. The end of the thermo-couple has to be in the flame of the pilot, and tight on the other end, and must be tight on the other end.
Posted on Dec 21, 2008
  • 10865 Answers
SOURCE: charmflow patio heater will not fire
turn the knob on very slowly just enough to fire up the heater. once it is fired up slowly adjust it.
Posted on Jun 24, 2009
  • 109 Answers
SOURCE: pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Posted on Jul 07, 2009
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
Weil McLain Clicks and then burners shut down
it needs a new thermal coupling ,this tell the gas valve to open if it goes bad your heater shuts off for safety reasons.
Nov 29, 2012 | Watches
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Gas boiler won't stay lit!
The burners and pilot need to be cleaned.
Turn off gas and power, remove the burners and pilot. Clean with a brass wire brush. (Steel wire can be used but very carefully) Remove all rust dirt etc. reinstall and it should fire right up.
Dec 28, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
