Why does energy saver automatically turn on when i turn on my air conditioner and how do i stop it
SOURCE: Energy Saver
Turn Power off, hold down the 8 & 0 keys while turing power on. Enter 11, depress start, enter 1, depress Interupt, hold down 0 & 9 keys and you have disabled Energy Saver
Posted on Jan 12, 2008
SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Posted on Mar 01, 2009
daddyo742001
  • 70 Answers
SOURCE: This goldstar air conditioner model is WG2405RY7
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Posted on Jun 30, 2009
relaga58
  • 158 Answers
SOURCE: air conditioner not working
have you tried turning off and on power from the plug ?
Posted on Aug 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rinnai Energy Saver 1001F
Try this link http://www.rinnai.us/documentation/downloads/Owners_Manual_1001-551.pdf
Posted on Sep 09, 2009
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
How can I turn on the energy saver on my LWHD2400HR air conditioner? There is no switch on the A/C, only an indicator light that says "Energy Saver"?
The Energy Saver mode is activated by using the hand held remote control, that comes with the unit. Pressing the Energy Saver button activates it. Once activated the fan will shut OFF when the the compressor does. After which, about every 3 minutes the fan will turn ON to check the room air to determine if cooling is needed.
It sounds like, you're missing the hand held remote control?
Jul 19, 2011 | LG LWHD2400HR Wall/Window Air Conditioner
Energy saver feature turns off unit but won't allow to restart or will just humm
Hello Jester The unit needs 5 minutes between running and restarting.Humming could mean overload let it cool.Turn it off 20min.Turn power saver off on HOT days.
Jul 08, 2010 | Amana ACEX186E Wall/Window Air Conditioner
Air conditioner not working
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Model number HBLG 12303r how does the energy saver setting work bought this model used.
The energy saver setting will turn the blower fan off when the thermostat reaches the desired room temperature (with the compressor). Other non energy savers only cycle the compressor to regulate the room temp. so their fans will operate continusously using more electricity.
Aug 04, 2009 | Heating & Cooling
I set ac at energy saver 71 degrees. The ac goes
yeah you have to be carfull the only thing that does is shut the inside fan off it does not mean anything. it is a selling thing
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
Beeping noises
try un plugging it for 30 sec and pluggind it back in and if that dosent work by pass the energy saver with a jumper from j1 to j2
Dec 19, 2007 | Frigidaire FAC052K7 Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
