Question about Cycling
How do I change the batteries on a Schwann airdyne console?
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Changed battery, need to restore time and distance to alter
To properly reset your mini computer to the specific mode you need please see Pg 8 - Pg 14 of this Airdyne manual from SportSmith I will be attaching a link of. Hope this helps.
http://www.sportsmith.net/images/product_support/schwinn/owners_manuals/AD4_Airdyne%20Evolution%20Comp%20Owners%20Manual.pdf
Apr 29, 2015 | Schwinn Original Airdyne
Replacement batteries for Schwinn Airdyne AD3?
It should just be 2 AA batteries. Remove the battery door on the back of the computer to expose the batteries. Remove and replace. Computer Graphite Airdyne Big Fan Schwinn 92823 SPORTSMITH net
May 16, 2014 | Schwinn 430 Elliptical Trainer
I Need Console for 1988 Airdyne
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
Good Luck.
Jan 06, 2013 | Schwinn Airdyne Ad4 Upright Bike
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
I need assembly picture or diagram for original airdyne.
Here is the diagram for the original Schwinn Airdyne. Only the computer is different.
Aug 25, 2010 | Schwinn Original Airdyne
I recently purchased an older schwinn airdyne and the console is missing the battery screw cap cover. I called around and it is no longer an available part. Anyone know how I might fix it without the cap...
I would take the cover of and expose the wire connection make sure you polarity is correct if you are good soldierer solder in long wires thru the bottom plate of console then solder a battey holder maybe a "AA" battery attach that with Velcro reassemble console ansee if it fire up
Feb 23, 2010 | Cycling
Owner's manual for older Schwinn Airdyne
http://support.nautilus.com/support/schwinn/uprightbikes/prdcdovr~3550012/Schwinn+Airdyne+Exercise+Bike.jsp
Follow this link and you can download the owners manual as well as the exploded parts schematics. There will be information about the different years. other than the consoles they have remained the same for 20 + years. If you ever need to replace the bottom bearing be sure to get the lock ring as well. It changed from left hand thread to right. Thats it. You can also upgrade the console to the newer version. A little expensive but with proper care a 20 year old Airdyne will last till the frame rusts out from under it.
Apr 23, 2009 | Schwinn 430 Elliptical Trainer
Cycling Logo
64 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
