I have ptac unit there is power on the 24v transformer but no display on light on the unit
  • 236 Answers
If you have a clamp tester, operate the unit with the clamp tester and check the current reading. If the current reading is normal but the reset button is tipped then there is something wrong withe power plug reset button. But if the current reading is higher than the name plate rating then there is something wrong with the unit.
Posted on Mar 09, 2008
  • 182 Answers
SOURCE: old carrier a/c unit
sounds like your contactor coil is shorting out.replace the contactor
Posted on Sep 24, 2008
  • 958 Answers
SOURCE: Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
Posted on Oct 01, 2008
  • 3 Answers
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Posted on Jan 27, 2010
KLR Monkey
  • 22 Answers
SOURCE: Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Posted on Feb 01, 2010
My thermostat says the heat is on and its set to auto but the furnace wont turn on we've reset circuit breakers turned the unit off and on checked the filter but it wont turn heat on.
Look for this. 24 volt transformer. Thermostat sends 24v to the unit in order to tell the unit to turn on. The transformer is probably bad or isnt getting power and the unit isn't getting the "turn on signal"
Get a test meter and touch the two screws. If it's not getting voltage, check the 120v wiring to it and make sure it's getting 120v. If it's getting 120v at the wiring but not 24v at the screws then the transformer is bad. Easy to change and common part. Home depot or Lowes for about $35
Oct 17, 2017 | Power Computers & Internet
I have a blodgett zephaire gl oven. unit kept buring up 24v transformer, was old bad centrifical switch in motor. I replaced motor with brand new one, unit still buring up 24v transformer.....why ?
A short somewhere causing it to overamp. Put a 3amp inline fuse on the secondary side (24v side) on the hot wire. This will save the transformer and blow the fuse not the transformer. The centrifugal switch prolly wasn't bad. So I would trace the wire coming off transformer and look for bare wire or loose wires. Anything that would cause a short
May 04, 2016 | Blodgett Ovens
Carrier ac light on board out
High voltage goes to board then to transformer. 24v comes out transformer into board. Check high voltage going to transformer if have votage but no low voltage out other side 24v then transformer is bad.
Aug 28, 2012 | Carrier Heating & Cooling
Goodman package unit pgb036075-1 issues. No light on control board
there is a fuse on the board which is very hard to see it is a three amp automotive style fuse most people cant find it it is purple in color look very closely using a flashlight
Aug 04, 2012 | Goodman GPC1342H21A Air Conditioner
I dont have 24 volt to c g r w y but my transformar have secendary volt.indicet flesing light flikar on #6. ineed to fix out side condenssor unit cantol by the tharmostatebut idont have 24v in r
Check for a fuse in the unit. make suree you have power to the transformer. There might be a door switch not making. If power is there but no 24V replace transformer.
Aug 18, 2010 | Goodman Heating & Cooling
I have a chance to buy several amana ptac units (ptc074D series) they are rated at 265 vac I only have 220vac. Will they work at 220vac? Is there a conversion kit needed?
The 265/277v units will not work in a 208/230v hotel without a transformer. Basically you do not want to get involved with that. When replacing your PTACs stick with the proper voltage. As far as a conversion kit, if one exists, the cost will put you right back at the cost of a new unit. If your hotel is wired for 208/230v it won't give the unit the power it needs to function properly. When looking for replacement units here's what you need to match (besides getting the proper BTUs):
Unit size (make sure they fit in your existing sleeves)
Power cord configuration (the 265/277v will have a different power plug)
Good Luck!
May 14, 2010 | Heating & Cooling
I want to find the transformer for the 36 volt inside unit. Is it in the inside unit or outside unit .I have no power to the inside unit however the outside unit has power,and the inside unit appears to be...
It's a 24v transformer. Your indoor unit houses the transformer for the outdoor unit. The outdoor has a low voltage (24v) supply running to it to push in the contactor for the outdoor unit to run. If your air handler inside has no power then it will kill your LOW VOLTAGE power to the outdoor unit. You will still have the high voltage power to the outdoor unit. You may have a fuse on the switch for your air handler blown if there is one. On the disconnect switch mounted to your air handler, you will have a door to open and a fuse in there. If not, check your main breaker at the panel. If you don't know what a transformer looks like, you may want to have someone familiar with electrical of HVAC help you. To check the transformer for power, you first need power to your air handler, which you don't have. I would say that is not your problem. I would assume your air conditioner is not running outside, correct? Your problem is the power (HIGH VOLTAGE) to your air handler. Loose wires, blown fuse, tripped breaker etc...
Aug 06, 2009 | Comfort-Aire HMC36AT-1 Air Conditioner
Blown Transformer heat pump
blown transformers are usually from a low voltage short the first thing i would do is wire a automotive or resetable 3amp fuse in line with the transformer so you dont blow transformer after transformer the wire coming off the transformer that say 24v take that wire a couple of inches down and cut it and install the fuse in series there
now you can go through your low voltage wires one by one and test them unhook all the wires to your outdoor condenser at your indoor unit(furnace or airhandler) and try turning it to cool now if you blow the fuse the short is between the tstat and the indoor unit if the fuse is still good leave it on cool and hook up one wire at a time to your outdoor unit starting with R a lot of times your contactor or your defrost board will short out on you also look for pinches in wires wires with cracks in the insulation and wires touching metal this situation can be a real pain sometimes i would recommend calling a hvac company if you start to get stumped
hope this will help you
Jul 26, 2009 | Ruud UBHC Air Conditioner
tnx 4 using fixya,
Oct 01, 2008 | Heating & Cooling
No air conditioning unit inop
you lost your 24v check the transformer at the furnace at R and C treminals see if you have 24v if not your transformer is gone but you also have to have the door switch on the blower section closed and check incoming power as well
Aug 17, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
