Question about Garden
I have a 2006 bush hog m2673 zero turn mower. Lately when it's hot outside it will run 35 minutes then it stalls out like it's out of gas. When it cools down it is fine again.
    New Friend:
  • 21 Answers
Clean your filter / exhaust system
Posted on May 18, 2017
Ford 2000 tractor stalled bush hogging (Too slow near the fence line, no engine prob). PTO was engaged, was in 2nd/high. Cant get it out of gear to restart.Cant lift the bush hog up--cant do anything.
Have someone help you rock the tractor back and forth and see if it lets go ,if not jack up rear wheels and rock them back and forth.
Aug 31, 2016 | Ford Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Pto on our 165 massey furguson will not turn fast enough to run bush hog can anyone trouble shoot?
Hi Lynn:
The speed of the PTO on every tractor I've owned has been directly related to engine RPM and there has been no other way to change it.
Did your bush hog work with it at one time? If it did, what has changed since then? That might give an indication of a possible fix. It may be that the tractor and bush hog are not compatible.
May 14, 2015 | Garden
Why does motor try to stall after cutting for 30 or more minutes? Acts like it is running out of gas but has full tank.
check your gas cap
then check the fuel lines, if they are soft or spongy, replace
then check for spark
in this order
Aug 20, 2014 | Toro Zero Turn TimeCutter SS Series SS5000...
Agri-fab help : we have an Agri-fab bush hog that we pull with our four-wheeler. It is not wanting to run and acts like it's not getting fuel to the motor. Does it have a fuel-pump or filter that I ne
BOTH, what's the engine make and model #. It would still run (poorly) with oldish fuel. STOP, what else have you done so far?
FUEL CAP has a vent usually. pretty dusty dirty back there, air is drawn into the tinney winney hole in the gas cap and sometimes will plug up.
Mar 29, 2014 | Garden
Engine runs great for 10 minutes and then stalls. Won't start until is sits 3-5 minutes. Replaced fuel lines, filter, cleaned carb., replaced spark plug. What else could be causing this?
Believe it or not, your gas cap is clogged up with dirt and debris. When a carburetor is unable to get a constant flow of air from outside, pressure builds up on the fuel tank. The fastest way to determine whether or not this is the problem is as follows.
As you are using your Mower, at that point when it begins to stall out, loosen the gas cap so that you release the pressure that is built up in the gas tank. If the engine begins to regain power, then you know it is a clogged gas cap. (Simply get a small wire and clear the breathe holes in the cap.) If the engine dies even after loosening the gas cap, then you may want to check to make sure the air breather is clean. ( A dirty air breather can cause the engine to over heat and stall out.)
If none of this seems to help, then it is probably a bad Ignition Coil.
Good Luck!
Jim
Jul 29, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Cuts out and then quits. In about 10-15 min. will start again.
I think that cooling off is doing it,I think your gas is filling you carb bowl,remove you carb and take bowl off ,I would buy a kit,I have had problem with the floats sticking or have been damaged by water freezeing,that carb is easy to rebuid you will do good and you will have the pride of fixing it ,good luck and thanks
Jul 28, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
