Question about Exercise & Fitness
My Nordictrack NTL79011 does not run and now will only "clunk" when hitting a speed selection. The display and incline all work but when selecting a speed it just clunks forward a bit and stops.
  • 225 Answers
SOURCE: Dishwasher makes a clunk noise
Hi. My guess is that it's the upper arm hitting something then! If it started suddenly I'd check that the upper bar attachment hasn't been dislodged from its proper location on the upper basket, and that the spraybar retaining nut hasn't come loose.
It happens on my machine all the time as the upper arm assembly has worn loose on the upper basket, AND the spraybar is worn where it attached to the static part so the whole thing wobbles as it goes round. An additional washer under the spraybar retaining nut might tighten it up a bit.
Hope this helps you a bit. If it does, a "Fixya" rating would be much appreciated. If it doesn't help you, I'd be grateful if you didn't bother with a rating at all. Cheers, D
Posted on Dec 02, 2008
SOURCE: 2004 jeep gran cherokee front end clunk
you must replace and lube the front sway bar bushings,chrysler service bulletin calls it a squak, but can sound like a rubbing, a clunk etc the common factor is this is really noticeable the colder it gets outside
Posted on Mar 03, 2009
  • 434 Answers
SOURCE: 2005 chevrolet 4x4 bang/knock/clunk
Sorry to tell you, the transfer case shift fork is going bad. Fix it ASA, or it will cost you another few hundred dollars for a planetary gear.
Posted on Jun 23, 2009
  • 154 Answers
SOURCE: Loud Clunking when jeep starts moving in drive.
may be the gears in the rear end or check your motor mounts, ive had the noise and it was motor mounts
Posted on Dec 06, 2009
mouse_kil
  • 93 Answers
SOURCE: My rain train works good for a short time, then
sounds like a broken gear you might have to replace it
Posted on Apr 12, 2011
Testimonial: "I pulled the housing off, and one of the gears was missing 5 teeth! Thanks for the help."
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack Elite XT Treadmill-display problem
1) Run the calibration software for easy diagnostic and fix it. go to owner manual, and go under the hood for following the steps.2) Exchange the batteries by new ones, cleanup contact from the batteries for oxide, and see if there are Not SOME WIRES BROKEN OR LOOSE.3) Tight the keypanel from flexible cable vs display board, 4) tigh the display board vs lower board. 5) attached the sensor reed switch by 1/8" or 3 mms adjusted according. 6) Test the main motor controller board for 115 Vca, and then +5 vdc for output coming to display board very important.
7) Test the transformer for primaRY VOLTATE see the tip adjust how to do it. 8) Finally see the block diagram that I did like like you for easy diagnostic and fix it.to.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
sincerely. Happy new Year. G-d bless you
ernesto cuadra
managua, nicaragua
Dec 21, 2011 | Nordic Track Exercise & Fitness
Nordictrack COmmercial 1500 console buttons don't work
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
How do you start the Nordic Track C2205? I have no book.
place the safety key in/on and hit start, select the speed desired and walk or run til your hearts content.
Jul 25, 2010 | Nordic Track 1dzn (12)treadmill Keys For...
Nordictrack Model A2550: Incline function!!??
this function is to give a little more intensity exercise, while helping to raise the heart rate and thus burn fat. watch it more practical as a stress test.can use the runner at a speed of 3.5 mph and an elevation of 7.5 of inclination and see good results
Feb 02, 2010 | Nordic Track NordicTrack Treadmill, A2550
Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Jan 12, 2010 | Exercise & Fitness
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
