Question about Carrier Humidifiers
Do carrier model #38TKB048350 have a build in Humidifier or is that separate?
2 Suggested Answers
  • 43501 Answers
SOURCE: I have a Carrier Weathermaker 9200 furnace
Here is the replacement for that unit...the price is not bad either...
Posted on Nov 30, 2010
I need a replacement part for humidifier, model#HUMCCLBP2317-A, part is a "Scale control insert"
Here is a link for the part you are looking for:
Oct 21, 2014 | Carrier Humidifiers
Humidifier Running Continuously with Fan Blower
As long as the humidifier start/stop is regulated by air flow there is no way to cycle it on/off with another device. If, however you disconnect that capability and, instead wire it to the heat on cool on switch it will only turn on when the stat calls for heating or cooling. You may need to install an intermediate relay off the stat wires to regulate the different(assuming that they are) voltage of the humidifier start/stop.What a fun project, thanks!
Jan 22, 2013 | Humidifiers
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
Low voltage to selenoid valve how do i correct this?
change and check another carrier LBP Humidifier
Jan 21, 2012 | Carrier LBP Humidifier
I have a carrier humidifier model BG49. When the furnace turns off due to reaching room temp. The water still continues to flow into the reservoir of the humidifier. Is this the correct operating...
Hello, The humidifier should turn on and off with the furnace's blower motor, If the humidifier keeps continously running than the solenoid valve is stuck open and should be replaced.
Jan 30, 2011 | Carrier LFP Humidifier
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
Carrier SBP Humidifier is not working
I would suggest turning up the humidistat (usually located on the the return air duct to a higher setting and listening for a "click" noise on the supply valve. If you do hear a click but dont see / hear any water than the culprit is likely the valve itself.
Nov 22, 2008 | Carrier SBP Humidifier
Carrier Humidifier MN# HUMCCLFP1218A - not working
First of all the white build up is hard water residue. If you haven't replaced the filter in 3 and a half years you NEED to replace it. They have a safety switch may not be satisfied because of your filter.
Dec 21, 2007 | Humidifiers
Humidifiers Logo
79 people viewed this question
Top Carrier Humidifiers Experts
Paul Carew
Mack Baxter
Tom Chichester
Are you a Carrier Humidifier Expert? Answer questions, earn points and help others
