Question about Dryers
Where is the dip switch? - Dryers
With me problem on konica minolta 7235 show error code f35-8
1. Turn OFF the SW2 (sub power).
2. While pressing the copy quantity setting button 2
and 5, turn ON the SW2 (sub power).
3. [Software DIP SW setting screen]
Select a DIP switch number.
Use the or key or numeric
To use numeric keys, press the DIP
switch number key at the left before
entering a DIP switch number.
select Dip 3 1 to 0 from 3 1 1
Mar 22, 2016 | Konica Minolta Office Equipment & Supplies
Head lights dont work on my 86 ford bronco II, new switch still not working
the main lights have dip and main switching
whats ever is up its the + side
so check the fuses and holders and wires and the dip main relays and main beem switchings
so...does the dip beam work if so its the relay or switch to dip main gone wrong
Dec 10, 2014 | Head Electrical Supplies
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
May 24, 2014 | Konica Minolta Bizhub C300 All-In-One...
Can I program a 10 dip switch remote to replace an 8 dip switch remote?
You should be able to, 8 dip switches gives you 256 addresses, the 10 dip switches gives 2048 addresses, just leave switches 9 and 10 in the off position and set the switched the same.
Jun 16, 2012 | FireFly 300mcd21k - 1 Button Keychain...
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dryers Logo
23 people viewed this question
Top Dryers Experts
