Question about Lenovo Computers & Internet
How do I get a good starting manual for the Lenovo ideapad 310?
  • 1606 Answers
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
Posted on Jul 09, 2009
  • 3530 Answers
Make sure you did it correctly. Computer should be OFF when doing the one key recovery. Turn off the computer then press the small button right beside the power button. Your computer should automatically turned on and you will go straight to one key recovery software. If this will not happen, then the one key recovery is destroyed. We need to re-image your Harddrive to have that one key recovery software back to you computer. You may call Lenovo technical support department for further assistance on how you are going to send your laptop to our depot department.
Posted on May 30, 2010
  • 13 Answers
SOURCE: i took one lenovo s10-2 ideapad. i was trying to m...
try pushing the OKR (One Key Recovery)button, because the lenovo has a hidden partition of the OS it self. the OKR button is located near on the ON/OFF button.
WARNING, if your going to do the OKR try to back your file first because once you proceed on the Restoring the computer back to factory setting. All your files will be gone
Posted on Jun 12, 2010
  • 128 Answers
SOURCE: User manual for Lenovo Ideapad S10 lap top
Click here to obtain Lenovo S10 Netbook Users Manual.
Should you have any other questions just please leave a comment.
Posted on Jul 12, 2010
  • 470 Answers
SOURCE: Hi, I have a Lenovo ideapad y470. I can't get it
What does it say? MBR is missing?
Posted on Apr 14, 2012
How to reset idea pad a10
Lenovo IdeaPad A10 Manual PDF & Hard Reset - We've important information for owner of Lenovo IdeaPad A10 especially about manual, hardware and care guide. The manual is available in pdf format and support in english language. The Lenovo IdeaPad A10 is powered by Rockchip RK3188 Cotex-A9 Quad Core 1. 6GHz processor. It's 10. 1 " HD inhes with DDR3L. It is equipped with 16GB/32GB SSD. It is also powered by 2 cells/22. 6Wh Polymer. While for operating system is designed Android.
The Lenovo IdeaPad A10 User Manual consisting of 66 pages. Inside the manual you could find reference information for example safety information like electrical safety and Laser compliance statement. Then about Strategy for replacing FRUs, Strategy for replacing a hard disk drive, Checking the AC adapter, Checking operational charging, Checking the battery pack, Power management, Removing and replacing an FRU like 1010 Battery pack, 1020 System board, 1030 LCD unit, 1040 Base cover, audio board, speakers and power board, and more.
How To Hard Reset Lenovo IdeaPad A10
  • First, ensure your device is fully shut down.
  • Press and hold the correct keys to boot the device into recovery mode.
  • try this key combination: Volume Up + Volume Down + Power Volume Up + Home + Power Devices With Camera Buttons: Volume Up + Camera NOTE: If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
  • Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
  • Press the Volume Up and Volume Down keys to scroll through the options until you see Recovery mode on the screen.
  • Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle
  • Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
  • Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen
  • Select wipe data / factory reset with the volume keys and tap the Power button to activate it.Select Yes - erase all user data with the volume buttons and tap Power. NOTE:Your device will be reset to its factory state and all your data will be erased.If your device freezes at any point, hold down the Power button until it restarts. goodluck icon_smile.gif
Read more: How to hard reset ampe a10 tablet? - I forgot my login password. Now my tablet is locked because of wrong entry passwords.Now i wanna to hard reset my tab.i need to hard reset my Ampe A10 Tablet
Table of content Lenovo IdeaPad A10 Manual/User Guide :
  • About this manual
  • Safety information
  • Important service information
  • General checkout
  • Related service information
  • Lenovo IdeaPad A10
  • Notices
follow the link for manual
Jun 25, 2014 | Lenovo IdeaPad Computers & Internet
How to clean fan on lenovo laptop ideapad U150
You can download a manual from this WEB and which may show how to access the fan to clean it.
Feb 18, 2013 | Lenovo IdeaPad U150 (690969U) PC Notebook
Lenovo Ideapad U400
On a lenovo Ideapad U400, there is a recovery key on the left side og the pc, press that, at follow the steps on the screen.
Aug 13, 2012 | Unknown Lenovo Ideapad U400 0993-28u 14...
Jul 12, 2010 | Lenovo IdeaPad S10 - 42312BU Notebook
Computers & Internet Logo
41 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
