Question about Exercise & Fitness
Correct time on fitbit - Exercise & Fitness
How do I set the time on my Fitbit ?
How to Change the Time on Fitbit
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 26, 2018 | Exercise & Fitness
How to change time on my fitbit watch. it is now 12:15 pm
hi Paul.
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner. -Scroll to the bottom of the Personal Info page and modify your timezone. -After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
SOLVED: Correct time cannot be set on my Fitbit - Fitbit zip - iFixit
or try this link.
How to change time on my fitbit watch Google Search
Dec 06, 2017 | Exercise & Fitness
How to reset time and date on fit bit watch
hi Sonja.
How do I change the time and date on my Fitbit?
  1. From the Fitbit app dashboard, tap or click the Account icon ( ).
  2. Tap or click Advanced Settings.
  3. Tap or click Time Zone.
  4. Turn off the Auto option and select the correct time zone.
  5. Sync your tracker.
Help article: How do I change the time on my tracker? - Fitbit Help
https://help.fitbit.com/articles/en_US/Help_article/1176 Search for: How do I change the time and date on my Fitbit?
or read up more at this link.
How to reset time and date on fit bit watch Google Search
Dec 03, 2017 | Watches
How do I change the time on my fitbit?
hi Elaine.
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner. -Scroll to the bottom of the Personal Info page and modify your timezone. -After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.13 Oct 2016
or try this link might help you.
How do change the time on my fitbit Google Search
Nov 18, 2017 | Exercise & Fitness
How to set time on fitbit
There are some specific things you can do depending ion what Fitbit you have, but without knowing that, here is some general advice. Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order. Check if your device has the correct time before moving on to the next step.
1. Re-sync your Fitbit to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
5. Try resetting your Fitbit (specific instructions depend on which one you have).
Oct 20, 2017 | Exercise & Fitness
The time is wrong on my fitbit hr
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
3. Make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit in your Bluetooth settings.
Hope that does the trick!
Oct 17, 2017 | Exercise & Fitness
My fitbit has the wrong time on it.nhow do i amend the time
Oct 07, 2017 | Exercise & Fitness
I can't find my instructions. how do I correct the time on my fitbit charge?
    1. Editing your timezone settings
      1. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard.
      2. Choose Settings > Personal Info and find the Time section.
      3. Choose your timezone and select your 12-hour or 24-hour display preference.
      More items...
      Help article: How do I update my Fitbit settings? - Fitbit Help
      https://help.fitbit.com/articles/en.../How-do-I-update-my-Fitbit-settings Fitbit
    Feedback
  1. The time is incorrect on my tracker's display - Fitbit Help
    https://help.fitbit.com/.../The-time-is-incorrect-on-my-tracker-s-disp...
    Fitbit
Jan 03, 2016 | Fitbit Charge Wireless Activity Tracker...
The time on my fitbit is incorrect. How do I correct. Currently it registers 9:43, but, I'm on Eastern Standard Time.
    1. Editing your timezone settings. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard. Choose Settings > Personal Info and find the Time section. Choose your timezone and select your 12-hour or 24-hour display preference.Mar 10, 2015
    Feedback
Jan 03, 2016 | Exercise & Fitness
How do you set time on fitbit surge?
I downloaded the Fitbit app on my iPhone , followed the steps to pair with the surge, and voila, the correct time is picked up from the iPhone automatically.
Mar 06, 2015 | Fitbit Surge Large-Size Fitness Watch with...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
