Question about Dryers
I have ceiling fans that does not work. I put new battery in remote. What should I check?
    Top Expert:
  • Dryers Master
  • 49,994 Answers
Check the fan switch is on check for circuit breaker
Posted on May 18, 2017
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
My hunter ceiling fan stopped working then the light stopped put new battery in remote and still nothing works
it has a receiver for the remote control inside the electrical jbox up in the ceiling it may got damaged or check for power .
Jan 14, 2011 | Hunter Heating & Cooling
I have an airworks remote for my light and ceiling fan, quit working waht can i co?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | Universal Remote Control Hampton Bay...
Hunter ceiling fan w/handheld remote. At times the fan will shut itself off and/or the light will go on by itself ( ie. no one has been near the wallswitch or remote)
1. check your bettery. put in a new battery. retry.
2. pull out the remote unit in the ceiling fan and check the wiring. be sure all wiring is securely wired together.
Oct 03, 2008 | Office Equipment & Supplies
Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054
I had a similar issue with my fans. The fix I came up with was my remote was faulty. An easy fix because I had 2 fans with the same remote.
Jun 29, 2008 | Dryers
Remote Control
Change the remote control batteries. Because of the motor construction, it needs to turn on in the highest speed setting. This is why it defaults to the high speed mode. Put new batteries in the remote and that ought to fix it.
Mar 04, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Dryers Logo
23 people viewed this question
Top Dryers Experts
