Question about Fishing
I have the 1276sli abumatic spincast reel. The issue is when am reeling the line in there is bump in the handle always at bottom as i crank the line in under load.
  • Fishing Master
  • 3,498 Answers
Hey michael,
Sometime when you add line to a spincast reel, where you tie the knot and wind line onto the reel, it makes a bump in the spool, this "bump" in the spool sometimes hits inside the reel everytime it makes a rotation....
Posted on Jun 24, 2017
  • 319 Answers
SOURCE: threading reel to reel
Depending on which brand of recorder you have, most do have a general threading scheme. As you are facing the unit, the supply (full) reel would be on the your left and the take-up (empty) would be to the right. Position the supply reel so that the leader end of the tape will be on the outside. Pull the tape end around the shut off sensor lever so that it moves freely. Now pull the tape leader between the rubber pinch roller and capstan (in the case the unit has dual capstans). If it has a single roller on the right side, pull the tape between the heads and then between the roller/capstan. If unit has dual shut off sensor levers, pull tape around this sensor as you did the first, making sure it moves freely. Then thread the tape leader into the take-up reel slot. Press play. Both reels should turn counter clockwise.
Posted on Aug 03, 2008
  • 3 Answers
You can find the manual here:
As for the reels, there are 2 possible solutions:
1: Try to find new old stock reels. The website for Polyconcept
USA (which made the Reel media center) has been down since 2008, so the company may have gone bankrupt.
I found one internet shop that may still have blank reels for sale:
2: You can use 1/8" Nagra reels which are still being made, the tape is the same 1/8"(3.175mm) width as the tape used on the Reel Media Center.
The Nagra reels have a different hub, so you will need to improvise and make your own hub adapter.
I found reels like that on Ebay:
Posted on Jan 29, 2009
  • 2976 Answers
SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Posted on Feb 20, 2009
SOURCE: Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Posted on Apr 16, 2009
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
Is first eye supposed to be off set
from what i can tell, yes and no. if you're using larger line then you can use a non-offset eye. but for smaller line the eye of offset as per the manual instructions which are still pretty vague
May 09, 2016 | Zebco 33 Bite Alert Spincast Reel
String only comes so far when you shoot has enough line no knots or anything seems like its getting caught on something
unreel the line and hold tension on it when reeling back onto spool some lines dig in worse than others .
Sep 07, 2015 | Zebco 808 Bowfishing Spincast Reel 808...
Where can I get an assembly diagram?
  1. Popular Daiwa Goldcast Spincast Reel Medium Heavy ... > Forum > Fishing Rods & Reels > Daiwa
    Popular Daiwa Goldcast Spincast Reel Medium Heavy Action, GC120 questions, common issues & problems. Find solutions, answers, DIY tips, repair advice ...
Jul 20, 2015 | Daiwa Goldcast Spincast Reel Medium Heavy...
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do I get my reel to keep from letting the line out while I'm holding down the cast button?
Hold the line with your index finger and against the rod itself. Then cast and release your hold
May 12, 2014 | Zebco 11 Authent Micro SpinCasting Reel...
Fishing Logo
91 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
