Question about Vacuums
The brush on the bottom of the healthy home vacuum works intermitantly
reddevil6
  • 1673 Answers
SOURCE: Bissel Healthy Home Vacuum
May have a bad brush roll motor.
Posted on May 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Vacuum 5770 intermitent spinning brushes
Change the belt, they stretch after a short time and then it can't drive the brush roll under load. The part # is 2031329
Posted on Jun 03, 2008
galati2k
  • 281 Answers
SOURCE: Bissell Healthy Home Agitator Brush Switch
you might have a bad belt ,could be stretched .but if its new i would take it back to where you bought it.it should still be under warranty
Posted on Apr 13, 2009
SOURCE: Bissell Healthy Home Vacuum
easy fix- mine did this too for a while bfore I figured out the handle wasn't aligning properly where attached. Give it a smack to realign it and it works again
Posted on Jun 08, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
Bissell healthy home vacuum brush is working intermitently not sure whether it;s the button, the brush, or something is clogged or what?
Could be the switch or the motor, or the circuit board. Take it to your local vac shop for diagnosis.
May 18, 2017 | Bissell Vacuums
The motor for brush won't turn on for the bissell healthy home vacum
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
How do you change the belt on a bissell 5770
The Bissell 5770/Healthy Home vacuum is actually fairly easy to change the belt on. The main thing you will need is a T20 screwdriver with at least a 4 inch shaft and a Phillips-head screwdriver. Four of the six T20 screws on the bottom plate are easy to locate, the last two are set deeper into the vacuum near the wheels. Once you have taken all six T20 screws out you will have to release the lock preventing the vacuum from tilting back so you can easily remove the top plate and gain access to the brush assembly. With the top plate off you will notice four Phillips-head screws holding a cover plate over the brush, simply remove them and you have full access to the belt.
Dec 07, 2009 | Bissell 5770 Healthy Home Bagless Upright...
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Motor that turns belt and brush isn't working
Are you sure it isn't the belt? If it is worn it won't turn the brush. If it is the belt then you can get them here:
Bissell Healthy Home Replacement Belts
Nov 11, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Bissell Healthy Home Vacuum brush stopped working. The hose attachment works fine, just the brush on bottom. Without taking it completely apart, it shows no sign of blockage. Any suggestions? Or, will I...
You will have to remove the bottom plate to get at the brush. The drive belt either slipped off or broke, this will have to be replaced.
Nov 08, 2009 | Vacuums
The brushes on my new healthy home vacuum wont rotate when the machine is turned on how do i access the belt location
If you turn the vacuum over so you can see the brush roll, there is a brush cover that is held on by (4) screws. Remove those screws and the base plate cover will come off. With the base plate cover off you can access the roller brush an belt. If you need a replacement belt you can get it here:
http://www.vacbelts.com/bissell-healthy-home-belt.htm
Oct 23, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
