Question about Black & Decker 1000w Power Inverter
B&D 400W Inverter won`t run my laptop
The inverter is definitely working - have tried with phone charger and a reading lamp. the voltage supplied is reading just over 200V so maybe a little low but these devices seem fine with that. The laptop i`m trying to run is 19V 6.3Amp so should only need 120Watts max so i`d expect a 400W to manage easilly but all i get is the inverter power light flashing. i`ve tried seperately with 2 full charged leisure batteries and still no luck. Anyone have any ideas pls?
  • 867 Answers
Even the smallest inverter can run a laptop, something is wrong with this unit
Posted on Jul 25, 2009
    President:
  • 1,714 Answers
Your numbers don't add up. Where are you 'seeing' 200volts. Your lap top power supply transformer uses 120 volts AC. Are you plugged into a 240 volt outlet or something? Your inverter should be 12 or 24 volts DC input; to AC power usually 120 volts AC. Check out you output plug, should read 110 - 120 volts AC
Monitor LCD of my sony vaio VGN CS 13 G/Q laptop is running blank. The monitor LCD light does not perform appropriately (its light is off. I can not read the monitor's LCD so I must add/connect external...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Sony Computers & Internet
I have a Toshiba A350D-S6848 laptop...when i hit the power button all the lights come on fan running, dvd drive running, hdd running, nothing on monitor
Sep 15, 2010 | Toshiba Satellite A305D-S6835 Notebook
Laptop is running but screen is very very dark. can just make out the welcome screen
Sep 12, 2010 | Toshiba Satellite A75-S211 Notebook
Screen doesn't work, when it does turn on it fades and I can't see it? Might be screen inverter? or lamp blown?
Sep 10, 2010 | Dell Inspiron 1525 Notebook
Monitor is dark but the laptop is working,
Sep 07, 2010 | Acer Aspire 3680 Laptop
Keyboard working but no display
Sep 07, 2010 | Computers & Internet
Screen light goes on then dims so low you cannot read
Sep 06, 2010 | Compaq Presario CQ60-220US PC Laptop
My compaq 610 laptop is not displaying when it is on but it keeps on running
Aug 30, 2010 | Compaq Presario Notebook
My Everex 3500 motor is running but the screen is black
Aug 27, 2010 | Everex NM3500 Laptop
400W Black & Decker Power Inverter Doesn't Power My LCD TV
The problem of your inverter is from
your battery .your laptop and dvd
player requires little current to
operate.But you tv requires more power
to run, if your battery is low you it will
not last for 3 minutes. If your battery
has a low current rating, it will also be a
cause, for example, if it is below
100ampere hour. Lastly if your battery
is bad i.e. if it reads below the
stipulated dc voltage Require by your
inverter to operate.
May 09, 2010 | Black & Decker Power Inverter PI400AB
Black & Decker 1000w Power Inverter Logo
660 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
