Question about Dishwashers
I accidentally opened the door before the cycle was finished. Now the child lock sign flashes and the dishwasher wont start there are 58 minutes left
techman
  • 3130 Answers
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Posted on Apr 14, 2006
  • 139 Answers
SOURCE: Door lock light flashing
Shame to say it but yes..
You board behind the control pannel is blown. this is caused by either a faulty door swtich or the motor.. Your model number tells me its most likely the door switch.. The control board will need replacing and the door swtich.
Getting to the board is easy only three screws near the soap draw. make sure you write which wires go where and to getto the door lock undue the door rubber if you needany further advice let me know
i have worked on more the 300 of these machines
Posted on Dec 24, 2007
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
SOURCE: My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Posted on Mar 01, 2010
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Dishlex DX203SX Dishwasher door wont close
check the lock maybe it flipped shut lock maybe getting stiff from steam?
Feb 07, 2015 | Dishwashers
Everything appears to have power and lights flash but the cycle with water does not start?
Make sure the child-lock or control-lock function is not turned on. The other likely possibility is that the door latch is not closing properly, or that the door switches that are part of the latch are not getting engaged. So if the dishwasher thinks the door is open, it will not start.
Sep 20, 2014 | Dishwashers
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Door locked open
The 9 was the minutes left in the rinse cycle. I solved the problem noticing that the door fastener had moved slightly to one side and as soon as I straightened it by hand the door closed and I could cancel the cycle. It is working fine now.
Jan 28, 2010 | Samsung 24 in. DB5710DT Stainless Steel...
Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
Feb 15, 2009 | Maytag 24 in. MDBH970AWS Built-in...
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
