No steam after trigger pull on turbosteamer 220 even though every attempt fails
Turbosteamer220 model# SC-130HZ
3 Suggested Answers
  • 4088 Answers
SOURCE: Steam doesn't come out anymore when I pull the
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Posted on Aug 15, 2009
  • 3 Answers
SOURCE: I have a turbosteam 6060 sunbeam iron. It will
If I was you I would either go to the Sunbeam site and in the search box enter the model name and number and get a download a manual for fixing the iron or troubleshooting problems. If that don't work Send the Iron back to the company for a new one.
Posted on Feb 11, 2011
How do I use a turbo steamer 220 portable?
if your talking about a 220 volt you will have to have a 220 plug in, otherwise most are 110 volt, fill with distilled water, apply appropriate pad, turn on machine and wait for the indicator lite to tell you its ready and go. i recomend a medium pace to let the steam do its work.
Jan 26, 2014 | Vacuums
Karcher sc 952 having problems with no steam coming out.
this machine uses an electrical solenoid to open the flow of steam from the heater..... the switch is in the hand trigger and the valve on the machine.... one of these is at fault
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 04, 2013 | Karcher DE4002 Steam Vacuum
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
I have a Hoover Steam Vac. Even though I don't
There in the trigger assembly is a release button that might be broken.
Nov 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Steam comes out the handle
You need to disassemble the wand and apply thread sealant tape to all joints. This should solve the problem.
Ray
Dec 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
No steam coming out
The fall might have damaged or moved the trigger so that it does not depress the valve on boiler.
Try removing the screws which hold the handle together. The cap needs to be removed to allow the handle to separate.
Once the handle is apart check the trigger piece looking for any broken parts.
Jul 07, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
19 people viewed this question
 Grubhead
Grubhead
