Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Disherwasher fills with water but will not spray
The water shut off valve shute water off into the dishwasher but the disherwasher will not spray from either the bottom or the top sprayers. dishwaser will drain fine and otherwise run normal except for the sparaying.
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Posted on Jul 25, 2009
Water leaking at dishwasher above water line coming from under sink Problems. serial no. fu5006784
shut off valve may be leaking, valve location dishwasher supply line connect to it if washer over flows when not using the valve is not shuting of reolase valve
Oct 14, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Water is not coming out. I have checked the spray arms and they are turning ok. All valves are on to the dishwasher. Any ideas?
The fill hose to the dishwasher goes into a solenoid valve to fill the dishwasher. Check to see that it is opening. You can check this but starting the dishwasher and listening, a solenoid valve will click open and shut. If not it needs to be replaced. Note: It helps to pull the machine out from under the counter to listen for this. Also, although not as likely, hard water sometimes can clog the water openings on the spray arms, CLR or Lime Away can take care of that (Take care to rinse and drain the dishwasher after using these products).
Apr 29, 2010 | Dishwashers
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
Fill valve does not shut off completely
Yes, replace the valve. Small particulate matter will eventually damage the valve.
Sep 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
No water spraying and there is water going to the dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jul 13, 2009 | Dishwashers
Will not clean dishes on the upper rack
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
Check the following to address this issue.
1. No water
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 06, 2009 | GE Dishwashers
Dishwasher top spray bar does not spray due to low water fill
Check the water hose going from the sink to the dishwasher to make sure it is'nt clogged, if there's a water shut off valve under the sink make sure it's fully open, also check to make sure the spray arms at the bottom of the dishwasher that supply water to the top rack is clean with no debris or obstructions in the spray hole's, the water entering the dishwasher should be at a warm temp, if it's cold the dishes will not get clean, you should have good water pressure from the house supply for it to fill properly, the float is also called a flood switch, it should not be activated during the water fill cycle, if it's activated it will shut off the water inlet valve and the wash cycle will stop or the dishwasher will drain, if your still having wash problems it could be a defective water inlet valve or a bad timer, if that's the case you might have to call an appliance repair man, hope this helps, good luck.
Mar 28, 2009 | Dishwashers
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
300 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
