Question about Heavy Machinery
Just installed rebuilt injection pump and injectors on 5103 JohnDeere. Bled system,have fuel to the pump but still won't start. Will fire with starting fluid. Timeing mark is lined up.
    Sergeant:
  • 241 Answers
You are 180 degrees out of time.
Posted on Aug 19, 2017
  • 4 Answers
SOURCE: no start
if it runs on starting fluid its a fuel problem.. check fuel pressure even if its a couple of pounds off, the vehicle will not run. but using starting fluid may give you the extra poundage you need to make it run . also check vacuum hose at pressure regulator on fuel rail
Posted on Aug 02, 2008
txkjun
  • 409 Answers
SOURCE: 1999 Volkswagon beetle turbo diesel injection pump
Was any work just done to this car? Timing belt? It is rare that these pumps go bad but I have seen a few shell out. If you are not familiar with the ALH diesel engine I would not try to replace it. You should take it to a shop that specializes in VW's.
Posted on Dec 29, 2008
SOURCE: the truck died,it will fire
CAN THE FUEL INJECTORS FROM A 8 CYLINDER 1990 FORD F150 TO A 6 CYLINDER 1990 F 150
Posted on Jan 17, 2009
SOURCE: air in fuel line between fuel filter and injection
Hi, before the pump it is a loose connection or maybe a pin hole in the pipe, check all the connections and pipes for seepage, after the pump it will be a leak, i knowit sounds the same but after the pump the fuel is under pressure. It would appear that your system drawing air rather than forcing air in. daveg
Posted on Mar 10, 2009
alicantecoli
  • 22326 Answers
SOURCE: I have a 1987 F350
take the shut off valve out of the injector pump and inside the valve is a round metal body with a rubber seal on the end ,check this seal hasnt swollen and stuck ,also check inside the primary fuel filter for any transparant pieces or crystal ,this is a problem i have been getting of late with people putting this bio fuel into the tank ,it causes this crystal stuff and it damages the injector pump as it passes through the filters and solidifies in the injector pump and kills them.just though before you start pulling it apart crack off a couple of injector pipes and get assistant to crank engine throttle wide open and see if its pumping fuel first this will give you some idea what to look for ,leave this answer in your e mail box so you can get back to me later after having a look ,but please remember the time zone difference
Posted on Nov 24, 2010
How do you bleed a diesel pump jeep Cherokee turbo diesel 3.1 5 cylinder 2001
we dont have this engine here, USA.
but i have the WG jeep book,
starting page 12 , chapter 14
FUEL INJECTION PUMP BLEEDING
(1) If the fuel injection pump has been replaced,
air should be bled at the overflow valve before
attempting to start engine.
(a) Loosen the overflow valve (Fig. 18) at the
rear of the injection pump.
(b) Place a towel below the valve.
WARNING: WHEN CRANKING THE ENGINE TO
BLEED AIR FROM THE INJECTION PUMP, THE
ENGINE MAY START. PLACE THE TRANSMISSION
IN NEUTRAL OR PARK AND SET PARKING BRAKE
BEFORE ENGAGING THE STARTER MOTOR.
CAUTION: Do not engage the starter motor for
more than 30 seconds at a time. Allow 2 minutes
between cranking intervals.
(2) Crank the engine for 30 seconds at a time to
allow air trapped in the injection pump to vent out
the fuel injector drain tubes. Continue this procedure
until the engine starts. Observe the previous WARNING
and CAUTION.
(3) Tighten overflow valve.
HIGH-PRESSURE FUEL LINE BLEEDING
WARNING: THE INJECTION PUMP SUPPLIES HIGH-
-PRESSURE FUEL OF APPROXIMATELY 45,000 KPA
(6,526 PSI) TO EACH INDIVIDUAL INJECTOR
THROUGH THE HIGH-PRESSURE LINES. FUEL
UNDER THIS AMOUNT OF PRESSURE CAN PENETRATE
THE SKIN AND CAUSE PERSONAL INJURY.
WEAR SAFETY GOGGLES AND ADEQUATE PROTECTIVE
CLOTHING AND AVOID CONTACT WITH
FUEL SPRAY WHEN BLEEDING HIGH-PRESSURE
FUEL LINES.
WARNING: DO NOT BLEED AIR FROM THE FUEL
SYSTEM OF A HOT ENGINE. DO NOT ALLOW FUEL
TO SPRAY ONTO THE EXHAUST MANIFOLD WHEN
BLEEDING AIR FROM THE FUEL SYSTEM.
Bleed air from one injector at time.
(1) Loosen the high-pressure fuel line fitting at
the injector (Fig. 19).
(2) Crank the engine until all air has been bled
from the line. Do not operate the starter motor
for longer than 30 seconds. Wait 2 minutes
(3) Start the engine and bleed one injector at a
time until the engine runs smoothly.
end quote.
pump timing is on next page
or tank filter line priming before. above.
Mar 22, 2016 | Jeep Cars & Trucks
Why doesn't tractor start after injector pump rebuild?
I'd be suspicious that the injector timing is not correct.
When the injector pump was rebuilt, it had to have been removed from the engine.
There will be timing marks on the gears and they have to be lined up for the fuel to be injected at the correct time.
Oct 27, 2015 | Garden
My john deere 2025r ran rough, then turned it off. Now it won't start. Cranks over fine, acts like it wants to start, but won't fire. Cleaned fuel filter, fuel lines, bled fuel lines. Pumped fuel through...
Did you bleed injectors? Pump primer pump up till you pressure, wait pumping crack a injector nut till you solid fuel. Than close. Go to next one, do the same thing.
Feb 28, 2015 | John Deere Garden
I have recently purchased a ford 1510 tractor with a 3 cylinder diesel. It seems to have low power and rough idle problem. Middle cylinder seems to not be firing because when i crack open fuel line to...
Hello, I'm not very familiar w/ your model but it could be a
timing problem, the fuel is not being injected at the right time
to fire. On a older J.D.such as the 820 ect. would not inject at the right time, there is a place on the injector pump that corrects it, however, I would call a ford tractor dealer, or go online to www.tractornet.com
and list your problem. There are many people on this site that can and will help you. Good luck.
Jul 11, 2014 | Garden
1994 CHEVROLET C1500 PICKUP 4.3L V6 vortek cranks no start backfiring thru the Throttle body fuel injection system. The Distributor has a small hairline crack under the reluctor wheel could this be the...
100 psi per cylinder is way too low--should be in the vicinity of 150-165 per cylinder
back firing indicates wrong firing order and as you have replaced the plugs etc check that you have the leads on the correct plugs in the correct order
the timing for the engine should be around the 10 degree btdc and not tdc
Mar 23, 2017 | Cars & Trucks
Can a fuel pump relay cause poor gas delivery
NO, the relay will either work or it won't. (Unplug it and look at it; if the terminals look corroded... replace it.) Most cars have fuel injection systems these days. In addition to the fuel pump that pumps fuel out of the gas tank... there is an injection system pump which is quite expensive. In order of operation: 1) have your injectors cleaned or replaced as needed (new ones run about $30 each), 2) have the injection system pump pressure checked and get a rebuilt pump if needed (brand new one ~$850), and 3) check the fuel pump. If the car has more than 80K miles on it, then suspect clogged or partially obstructed injectors. A BOSCH SERVICE CENTER has a machine to test and clean most makes of injectors. At the same time, replace your fuel filter and use good gas when you fill up. NEVER fill up from a station that just had a fuel truck delivery (if you see the tank truck) as the garbage on the bottom of the tank takes a day or so to settle back down again. Magneti Marelli Check Star also offers good injection system servicing. The dealership should be your last resort as they just replace parts until the problem goes away... leaving you with a hefty bill and a bag of old parts
Aug 27, 2012 | Cars & Trucks
88 Chevy P30, diesal. Rebuilt injection pump, new starter, flexplate, fuel filter, new batteries, new cable connections to batteries.......STILL won't fire. Glow plugs tested and ok'd, cranks good just...
Did you loosen an injector line to see if you are getting fuel to the cylinder? Did you bleed the filter when you changed it? Was the rebuilt pump properly timed when it was installed? Are you sure all the air was bled out of the system after the pump and filter were changed? Do you have air bubbles in the fuel return line?
A copy of Haynes Diesel Engine Repair Manual, part #10330 ($20) could prove to be invaluable to help you track this down. It has excellent coverage of GM 6.2 and 6.5 engines. Hope this helps.
Mar 18, 2011 | 1988 Chevrolet K1500
Getting fuel to throttle body, but, car will not start. Fuel injected system. Injecters are not firing. Starts when gas is poured in throttle body then dies. What's my problem?
Sometimes there is a fuse just for the injectors if none of the injectors are firing id check the fuse.
But first check to see if the fuel injectors click because if they do click it could be the fuel pump.
Are you able to figure out what the fuel pressre is at when you prime the system? You can do this by checking the schrader valve on the fuel rail by plugging in a gauge and see if it has pressure when you turn the key.
if the injectors dont click and you have fuel pressure check the fuse for the fuel injector system (depending on model fuel injector system.) Cause you need to first make sure the fuel injectors arent firing cause it may be a pressure regulator problem or a fuel pump.
if you need further assistance or have a question about anything ive said please follow up with a comment and i will be glad to assist you further from there. Thanks and good luck.
Aug 26, 2010 | 1985 Cadillac Eldorado
05 f350 will crank but wont start changed fuel filters bled fuel made sure im getting fuel on top of motor
Have you checked the HPOP? You need to hook a guage and check your high pressure pump to see if it is putting out pressure. These units are prone to failure becaue they have such close tolerances inside of the pumps. Diangosis of these tuck is not for the back yard guy so be careful if you do not know these units or what they do. This system puts out i believe 1200 psi. The system is called a heui. Hydraulic Electronic Unit Injection. It is the high pressure used to fire the injector. You may be getting fuel but if you have no "plunger" so to speak to fire the injector you will get nothing. Also check Your IPR for a broken wire or a short.
Feb 09, 2010 | 2005 Ford F 350 Super Duty
Heavy Machinery Logo
1,220 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
