Question about Refrigerators
My ice maker on my samsungrf4287hars will not drop ice from the dispenser
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
tborn6
  • 700 Answers
SOURCE: Samsung Refrigerator Model RS2533SW - Ice Maker Stuck
did that work?
Posted on Feb 04, 2009
tborn6
  • 700 Answers
SOURCE: ice maker will not dispense ice
your gpoing to have to thaw out the pan that has all the ice in it the the auger will work
Posted on May 24, 2009
I have a Samsung rs261mdrs side by side refrigerator. The ice maker quit working. I replaced the ice maker, it filled with water after a few hours I check for ice. It's frozen in the ice tray but won't...
Is it that the ice maker unit won't drop to the tray ? or the ice from the tray will not dispense trough the door? I need more clarification to try to help...thanks
Mar 04, 2015 | Samsung Refrigerators
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Jul 25, 2014 | Kenmore Refrigerators
Why does my ge pss26lg side by side despense water but no ice?
Just because you get water from the dispenser does not mean you should also get ice made in the ice maker. Fact is there are two side to the water control valve. One for the ice maker and the other for the water dispenser. Is there ice remaining inside the ice maker slots? If not then pour water into the tray until full and if after the water freezes it drops the ice into the ice bin this will indicate a defective=> WR57X10032 Water Inlet Valve If nothing happens and the ice maker tray are full of ice this will indicate a defective=> WR30X10093 Ice Maker Assembly The ice maker is cannot be rebuilt on this model. I am here if you have questions, Thank You, John T Appliance 911
May 07, 2014 | GE Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
SIDE BY SIDE ICE MAKER MAKING ICE BUT NOT
Perhaps the dispenser have a, ice jam or it's clogged. Using a hair dryer, blow some hot air to the dispenser to see if the ice - if any- melts.
Aug 30, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
