Question about The Office Equipment & Supplies
Error code on screen said to change separator element I already changed the element
How do i fix error code L4-06 on sharp MX-2300
Trouble content
When separating the primary transfer belt unit,
change in the separation position sensor
characteristics is not detected within the specified time.
Section
PCU
Case 1
Cause
Harness connection trouble between the PCU PWB
and the separation position sensor
Check and remedy
Check the harness between the PCU PWB and the separation position sensor.
Case 2
Cause
The belt position sensor is not interrupted or it is always interrupted.
Belt separation clutch operation trouble
Check and remedy
Use SIM6-3 to check the belt separation operation.
Case 3
Cause
The primary transfer belt unit is not installed.
Check and remedy
Install the primary transfer belt.
Hope this help you, good luck!!!
Nov 23, 2015 | Sharp MX-2300N Color Copier
Why error code E000000-0001
it is the encode on the fixing unit / fuse unit change the fixing film and then reset the error code by entering service mode then clear it
Oct 12, 2015 | Canon ImageRunner 4570 | IR4570 |
I forgot my nokia c1-01 security code
The default code supplied with the device is 12345. However, it is recommended to change the default code to your own. The instruction on how to change the security code is provided in the user guide or Nokia Web site.
Keep the new code in a safe place separate from your device.
If you get error notifications after 3 consecutive times security code entries, reboot the device and wait for 15 minutes, then try again. If the problem persists, contact your local Nokia Care Point.
Oct 12, 2013 | Nokia C101 Cell Phone
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
F 03 showing on machine
Yes F-03 indicates a faulty thermistor (it's inside the heating element at the back). Before calling an engineer, just open the bottom rear panel and check that the connector has not come loose (OR IN MY CASE FALLEN OFF COMPLETELY). This can happen if there is a spin cycle that runs out of balance big time. (two thin wires on a square unit about 5mm in size fitted to the middle of the heating element).
Jul 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
The copier just produces blank sheets.There is still a lot of toner left. Is there any thing that i can do to fix the problem. There are no error codes except for a picture of a wrench on the screen.I dont...
Your problem in the transfer /separator high voltage parts.Change the transfer/separator corona wire and the corone front and rear holders.100%is working.(the causes is the air humidity)
Nov 08, 2009 | Konica Minolta Office Equipment & Supplies
F5 error code
when F5 comes up on the Duets it means "water temperature Sensor Error". what you need to check is the sensor, (which you have indicated has been changed), the heating element and the element relay. check all the connections to the Sensor, element and the relay first. hope this helps.
Nov 07, 2009 | Whirlpool Washing Machines
Error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
May 03, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
14 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
