SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
SOURCE: How do I replace the Drive Belt on a Craftsman
You need to get underneath the mower.Look in the front on the bottom of the engine.You will see the engine pulley.On the side of the pulley you will see a bracket that keeps the belt from falling off the pulley.It is help on by two bolts.Take the bracket off.Now you will be able to take the belt off.
Reinstall the new belt and replace the bracket.
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
