Question about Ovens
I have a Broan model 732-A and both lights have gone out. How do I remove the glass covers to change out the bulbs?
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
Posted on Nov 25, 2007
  • 1462 Answers
SOURCE: Can't figure out how to change the light bulb in the oven
normally the cover just unscrews but may be difficult if not removed for a long time - large pair of grips will help
Posted on Nov 26, 2008
jmeredith
  • 417 Answers
SOURCE: Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Posted on Jun 29, 2009
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Posted on Feb 28, 2010
SOURCE: cant remove glass cover to
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Posted on Jan 15, 2011
How do I change the bulb inside the oven
The glass cover unscrews counter clockwise and removes to be able to access the bulb itself. Note there may be a guard that has to be removed before accessing the glass cover
Apr 15, 2015 | AEG Ovens
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Change light bulb smeg oven
The glass bulb probably is a bayonet or screw fitting.
Nov 25, 2017 | Ovens
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
I need some help please, The bulb has gone in my oven! how do I change this and where would I get a bulb? The oven is a candy and the model number is FPP403.
Most ovens use appliance bulbs that can be purchased at any home improvement store. Open oven and locate the glass protective cover and remove it. Remove bulb and replace w/new one, place protective cover back.
Apr 23, 2011 | Candy F248P Electric Single Oven
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    How do I change the light bulb in the oven
    You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
    Apr 24, 2009 | Philips Ovens
    Unable to remove the glass cover to change the light bulb in oven
    Jan 12, 2009 | Ovens
    Ovens Logo
    24 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
